Why two "Eco" lights 2011 ls 460
Old 10-16-12, 01:28 PM
Zammer
Zammer's Avatar
Default Why two "Eco" lights 2011 ls 460
I just purchased a 2011 LS 460. Its 820-page owners manual is daunting, says a lot, but not enough about many things. There are two ECO lights on the instrument panel. One can be turned off by pressing the ECO MODE switch, which I did, because I don't want to be in ECO. But another instrument panel light saying ECO comes on when a certain speed is reached. The ECO info panel also comes on. Can someone please tell me what's going on, and how do I get out of ECO? Thank you
Old 10-21-12, 06:50 AM
gkcmilner
gkcmilner's Avatar
One ECO light is to help you monitor your driving habits. It can be turned off in the instrument panel display. The other one that you turned off with the button puts the vehicle driving dynamics in an economical mode where the throttle (have to push the gas peddle further to get the same acceleration), transmission (up-shifts come sooner and you have to push further on the gas pedal to get a downshift), and AC are modified to help the vehicle get the best gas mileage.
Old 10-22-12, 11:04 AM
Zammer
Zammer's Avatar
Thank you, GK., for taking the time to reply.
Before the 2011 460, I owned for 15 years a 1994 400. Its owners manual was 250 pages, v the 460's 800+ (plus three subsidiary manuals). I got the 2011 for its safety features. I find the 400 to be quieter and smoother riding than the 460. I suspect the tires and will start a new thread about other's experience with the Dunlop Sports that came with the car.
Old 10-23-12, 06:41 PM
gkcmilner
gkcmilner's Avatar
My last LS was a 2006 LS 430 and it was quieter in some ways and rode better in some ways. But now I have the 2012 LS 460 Sport so I guess I should expect it to be a little harsher. The Dunlop Sport Maxx tires make a little more noise than the Michelin's I had on the 430. I think the ride compromise has more to do with the 19" tires and air suspension (which from what I understand is a little harsher around town). But one thing is for sure; it handles much better, and the high speed stability is significantly better.
Old 10-30-12, 11:52 AM
Zammer
Zammer's Avatar
Default It gets odder
Hi all, After getting independent diagnoses from three sources that there was a suspension problem, I took the car to Lexus San Diego. I didn't go until I sure there was a problem.
The shop chief and I took a test ride. He said there is a free front suspension "update" that would fix the "diving when braking" problem. He showed me the bulletin; it exactly described the problem,.
He soon came back, perplexed: The update was for 2007-2010 LS's; the problem was supposed to have been fixed in 2011 models.
He thinks it is probably a control arm problem. They will put it on a lift check them. The suspension shop had done this and found them loose, so the Lexus shop should find the same thing, and install/replace as necessary under the warranty. I say"should" because with car dealers one never knows.
The shop chief said that was all they could do (if they do it), there is nothing else that affects ride and braking, other than tires, and I have Michelin Energy Saver on order at a tire shop.
I'll keep you posted.
albasheer
LX - 3rd Gen (2008-2021)
09-04-18 10:15 AM
W5YJB1
09-02-18 08:58 AM
vzjoseph1
07-25-18 09:25 AM
LexFather
02-20-11 06:38 PM
mewhee
09-24-10 12:03 AM
Quick Reply: Why two "Eco" lights 2011 ls 460
