LS 460 Factory Streaming Audio
Old 03-05-12, 12:27 PM
gxdude
gxdude's Avatar
Default LS 460 Factory Streaming Audio
Hi What year did they add Factory Streaming Bluetooth Audio on the LS 460?
Old 03-05-12, 02:38 PM
cheez80
cheez80's Avatar
my 2008 does not have it, so i'm assuming it showed up with the gen6 nav in 2010
Old 03-05-12, 04:11 PM
adamls2
adamls2's Avatar
Yep, with the new 6th gen nav system Bluetooth streaming is available which was available on the LS starting in 2010. One of the coolest features I wonder if it's possible to switch out the 5th gen system for the 6th? It would probably cost a lot of money though...
Old 03-05-12, 04:19 PM
nsaldanh
nsaldanh's Avatar
Try this out on a pre 2010 LS
http://us.blackberry.com/smartphones...ic_gateway.jsp
It's a music gateway. It is connected to you aux in on the car and your iPhone or other blue tooth device pairs with it.
Old 03-05-12, 05:19 PM
adamls2
adamls2's Avatar
That's actually a pretty cool idea!!! Is there one that works with the iPhone??
EDIT: I read that it works with the iPhone. Just order one from amazon. Now I won't have that annoying wire sticking out of the center console
Old 03-06-12, 01:17 PM
MikeE12345
MikeE12345's Avatar
I have a 2011 LS460 and my iPod Touch is paired with it and the BlueTooth works just fine. No need to plug anything in - it just works. I discovered, to my surprise, that it would even pair if my iPod Touch is in the living room of our home and I start the car in the driveway. So I can listen to tunes from it until I drive off and the connection is broken.
Old 03-06-12, 08:20 PM
PeachyKeen
PeachyKeen's Avatar
I've actually used about 3 of these. They are iPhone / iPad compatible. They do work well. Note, they do require a power source via a USB mini connector at all times (does not hold a charge). This should be simple enough to wire up for even a novice. Pairing is also simple. They work very well, they are small, and you can easily mount them out of sight behind dash etc.
Old 03-06-12, 08:44 PM
adamls2
adamls2's Avatar
Yeah, I also ordered a usb power cord for it and a double usb lighter plug thingy
I have used a belkin aux cable for a year now and it is so crunched up from being pinched
Old 03-07-12, 08:28 AM
vancouverl
vancouverl's Avatar
hay this works great .it will solve the streaming problem iv tried them all this is as good as factory streaming
http://www.newpotatotech.com/TUNELIN...link_auto.html
Old 05-24-12, 11:49 PM
MacLexN
MacLexN's Avatar
Does anyone else have a problem with engine noise while using this device? How do I fix that?
Old 05-26-12, 09:05 AM
nsaldanh
nsaldanh's Avatar
If you are referring to static or crackling then you probably have a ground loop somewhere in your signal path. Try disconnecting the power and the signal cable and reconnect everything. It might go away.
Old 05-26-12, 03:50 PM
dimapb
dimapb's Avatar
I had the noise. There is a TSB for it. If your car is still under warranty, go get it done. Resolved the issue right away.
Old 05-28-12, 12:06 AM
I8ABMR
I8ABMR's Avatar
there is an aux output TSIB for noise. You get an annoying whining noise when you accelerate . I had it done and it worked pretty well but then I ended up just getting an ipod adapter
Old 07-26-12, 10:48 AM
LBROWN557
LBROWN557's Avatar
Hello, I was wondering when your ipod is paired are you able to access your albums and playlists from the nav screen? the manual says i should have this capability but my screen only shows the one song that is playing...
Old 07-26-12, 01:46 PM
Valley101
Valley101's Avatar
Default Music in LS460
I have a 2012 and it shows Artist, album, song, which folder and which file.
Quick Reply: LS 460 Factory Streaming Audio
