Help! Where is TPMS sensor in LS 460?
Old 07-29-11, 03:36 PM
eddie_k_
eddie_k_'s Avatar
Default Help! Where is TPMS sensor in LS 460?
Does anyone know where is the tpms sensor located in our cars?
I Want to disable it...
Has anyone disabled their tpms?
Old 07-29-11, 04:51 PM
cmasten
cmasten's Avatar
sensors are in all 5 wheels built into the valve stem. This includes your spare.
You can have 2 sets of wheels and it will keep track, but I am not aware of being able to turn it off... not sure why you would want to, you paid for a very good safety feature.
Old 07-29-11, 08:24 PM
eddie_k_
eddie_k_'s Avatar
I had 2 tps sensors go bad in the last 6 months and I am tired of paying to replace them. I on my LS 430 I was able to just unplug the module but I cant find in the 460.
Which gives me the freedom to change wheels when I want.
Old 07-29-11, 09:55 PM
rominl
exclusive matchup
rominl's Avatar
i have no idea where the module (brain) is in the ls460
Old 07-29-11, 10:07 PM
telmz1
telmz1's Avatar
I thought the LS460 could only store 1 set of TPMS sensors?
Old 07-29-11, 10:43 PM
adamls2
adamls2's Avatar
i really want to find out if this rumor is true or not...
Old 07-30-11, 06:55 AM
cmasten
cmasten's Avatar
I dont have a set of winter tires, here in So Cal, but do remember reading that piece of info here
https://www.clublexus.com/forums/ls4...ng-wheels.html
looks like most of you gents were on this thread also... and it ends with the same question... so I dont know I guess :-)
Old 07-30-11, 08:41 AM
MikeE12345
MikeE12345's Avatar
According to my SA I must have the TPMS codes reprogrammed every time I switch tires from/to winters. Very annoying! There should be a capability to store two sets as other models/manufactures do.
Old 07-30-11, 09:42 AM
WhitBaby
WhitBaby's Avatar
Correcto-mundo. I had an '06 GS430 that could accommodate two sets of wheels via switch above passenger foot well.
Our "Flagship" LS460 doesn't have that feature.
Whit
Old 07-30-11, 12:41 PM
cmasten
cmasten's Avatar
come to think of it... my GS did have a switch.. I never used it, but presumed that the LS would.. interesting that it doesn't for as many flagships as there are in the colder states where people would want to switch tires.
Old 07-30-11, 01:32 PM
PRSUIT460
PRSUIT460's Avatar
I was told from my SA that there is only one set for the LS460.
Old 08-13-11, 03:52 PM
eddie_k_
eddie_k_'s Avatar
Update... I went to Lexus and they were able to tell me where the tpms module is located. Unfortunately, merely unplugging it does not disable the tpms. There are two parts to the system, the ecu and the receiver.
The ecu is located behind the glove box, the receiver is supposed to be some where on the right side. Not sure whether in the door or in the B pillar.
I also discovered there is supposed to be a reset button in LS460 as there was in previous models as in the GS430... It's shown on the service manual but I could not find it. Its supposed to be in the driver footwell.
Old 08-13-11, 04:30 PM
randomwalk
randomwalk's Avatar
The button is right where your right knee is. Just stick your head down there and look up.
Old 08-13-11, 04:46 PM
cmasten
cmasten's Avatar
harder to see the reset, but you will definitely see the system volume ****, when you see that the reset is next to it.
Old 08-14-11, 03:08 PM
eddie_k_
eddie_k_'s Avatar
Yup I found it yesterday after I posted... My bad...
Quick Reply: Help! Where is TPMS sensor in LS 460?
