View Poll Results: Regular, Mid-Grade, or Premium?
Regular
10.00%
Mid-Grade
0%
Premium
36
90.00%
Voters: 40. You may not vote on this poll
Gas: Premium vs. Regular advantages, disadvantages (merged threads)
Old 05-14-11, 08:38 AM
  #76
Silverpaws
Silverpaws's Avatar
I use premium and mid-grade only occasionally. Would there be any performance differences for your car if you used premium?
Old 05-14-11, 09:02 AM
  #77
vancouverl
vancouverl's Avatar
No performance differences I could tell.
Old 05-14-11, 09:33 AM
  #78
305Busa
305Busa's Avatar
I used regular gas on a recent trip out of town because the gas station only had regular and was the only station for another 50 miles and I filled up because i didnt want to make another stop. Car ran the same at highway speeds. Didnt feel any difference. Ive been thinking about trying it on the city. I thought I'd read a post somewhere that stated that the computer adjust the timing on the car based on the octane.
Old 05-14-11, 11:13 AM
  #79
Helmar
Helmar's Avatar
I believe that's correct, but how does the computer know the octane of the gas you just put in?
My understanding is that the engine "Listens" for a ping, indicating a timing problem caused by low octane gas and then adjusts the timing based on that ping.
HBH
Old 05-14-11, 12:50 PM
  #80
WhitBaby
WhitBaby's Avatar
Originally Posted by vancouverl
I own a ml Mercedes and it calls for premium I've used regular gas from new .it has 250 000 miles on it and has not had engine problems . Ls calls for premium as well .do any of the members use regular?
I burn Regular, but then I live in the Denver area and we can get away with it at this altitude. "Regular" is 85 octane around here.
Made a x-country trip to FL last October and could tell it really wanted the higher octanes. Under hard acceleration it didn't have near the poop it usually has. Mid grade was better, Premium made all the difference in the world.
Under normal driving just piddling around town, probably wouldn't make any noticeable difference.
Why do I cheap out on the gas? ... so I can buy another Lexus some day.
Whit
Old 05-14-11, 01:12 PM
  #81
LiveWire
LiveWire's Avatar
Vancouverl, what year and model ML? I remember my mom had a ML 320 when they first came out, and right around 70k on the odo, it had developed an oil leak that none of the local benz dealers could fix. We ended up practically giving it away. Got her into Lex GX 470 and she loves it. She wont get rid of it for anything to this day.
Old 05-14-11, 01:47 PM
  #82
Craig B
Craig B's Avatar
I only run 94 octane premium Conoco/Phillips in mine. It only costs a few bucks more per tank. I would only run regular if I was out of fuel and that's all there was available. You won't get the power or fuel mileage running regular. It retards the timing and that cuts down on power and fuel mileage...
Old 05-14-11, 01:51 PM
  #83
the.wong.k
the.wong.k's Avatar
lexus recommends the highest grade of gas, but you can run regular and it'll be fine, just expect the fuel injectors to run a little louder than usual. that's all.
Old 05-14-11, 06:29 PM
  #84
vancouverl
vancouverl's Avatar
mine is a 2002 and yes i have the famous oil leak as well you have to drop the engine to fix it .it is from the oil sensor .its not worth anything but boy is it good in the snow ill hang onto it till it dies.
Old 05-14-11, 06:42 PM
  #85
Grisik
Grisik's Avatar
All I use is regular. Still get 24.3 mpg around town. Always have more than enough power.
Old 05-14-11, 07:15 PM
  #86
PRSUIT460
PRSUIT460's Avatar
The engine is designed for premium so I use premium.
Old 05-14-11, 08:47 PM
  #87
derpie
derpie's Avatar
I feel a difference if I use 87 octane ...
Old 05-14-11, 10:18 PM
  #88
bsl888
bsl888's Avatar
It's top of the line Lexus, manual says 91 octane and above, so I follow the manual. If you can drive a $70K car, you can afford the few extra dollars. Just eat McDonalds' dollar menu items, instead of fancy restaurants.
Mythicalni (05-18-22)
Old 05-14-11, 10:47 PM
  #89
derpie
derpie's Avatar
lol you are right .
Old 05-14-11, 11:15 PM
  #90
I8ABMR
I8ABMR's Avatar
+1
Quick Reply: Gas: Premium vs. Regular advantages, disadvantages (merged threads)
