oil leak on LS460 L
Old 04-28-16, 01:45 AM
1Putt
1Putt's Avatar
Originally Posted by kshrews196
Thanks so much for parts link. Its nice to be on Lexus Forum and getting help from follow Lexus owners.
Check mylparts.com and lexussouthatlantaparts.com, these sites seem to be the cheapest nowadays
Old 04-28-16, 04:28 PM
Falbz
Falbz's Avatar
Originally Posted by roadfrog
I think the suggestion of the fuel pump leaking is valid. I believe the fuel pumps are mounted on the valve covers and when the gaskets connecting them to the valve covers fail, they leak oil not fuel. At least that's how I see it.
The statement is definitely valid as I had both fuel pumps rebuilt with kits under my extended warranty. Between the parts and labor it came out to about $350 or so total. I was leaking oil just like the original poster and not fuel.
Tech found:
"Found left and right side high pressure pumps leaking oil from hardened oil seals"
Part #'s
2 - Gasket Fuel Pump SP 23224-38010
2 - Insulator, Fuel Pump 23915-46011
4- Orings 90301-A0029
4 - Fuel Pressure Gaskets 23279-74010
The following 3 users liked this post by Falbz:
CamelKool (08-09-20), diamente (05-21-18), Rajananda (02-10-22)
Old 04-28-16, 04:41 PM
Falbz
Falbz's Avatar
Originally Posted by Tec80
There are 2 fuel pumps, one on each rocker cover. You'd likely have a bunch of smoke and burning oil smell if the o-rings sealing the pumps to the rocker covers were leaking, because the oil would drip right down onto the exhaust manifold.
Attachment 385043
I never had any smoking or burning oil smell when mine was leaking. Definitely possible but not in my case. Mine had to be a very small leak because I never had any puddles/issues. Hope it helps anyone in future.
Old 04-28-16, 08:01 PM
1Putt
1Putt's Avatar
Tech found:
Part #'s
I'm hoping my situation is like yours and not a leaking valve cover gasket
Old 04-29-16, 03:10 AM
Doublebase
Doublebase's Avatar
If it is, that looks like it'd be an easy fix. I remember seeing those fuel pumps when I did my spark plugs, if I remember they don't look too bad to get to. Of course we are talking high pressure, so the fuel will need to be bled off (I don't know what the service procedure is, but I imagine you can pull the fuel pump fuse and run it until it runs out of gas?). How much could those seals and gaskets cost? I think the fuel pump gasket comes included with most valve cover gasket kits anyway.
Old 04-29-16, 03:48 AM
Rhambler
Rhambler's Avatar
I think the original poster had indicated it was a leak in the oil cooler line.
However, what others have mentioned about the high-pressure fuel pumps just reinforces how I feel about them being a gigantic weak link in ANY direct-injected engine.
Just have to scratch one more item on the eventual failure bucket list on any direct-injected engine looking to exceed 100k miles IMO. In other words, the probability of failure on these things are extremely high and one could reasonably expect them to fail, either moderately or catastrophically, at high costs. Or simply put, if you plan on driving a direct-injected engine more than 100k miles, I would have a couple thousand ready for replacement.
Old 04-29-16, 09:18 AM
Tec80
Tec80's Avatar
That's not an oil cooler leak, it is the transmission cooler!
You should change your transmission fluid if it looks like engine oil....
http://www.lexussouthatlantaparts.co...ssembly=785153
The following 2 users liked this post by Tec80:
SENSAY813 (04-25-22), sha4000 (11-28-17)
Old 03-06-17, 07:09 PM
fblonk
fblonk's Avatar
I did both fuel pump seals at the valve cover for under $40. There is a thread on this forum that has a video on how to replace the drivers side gasket. I posted a reply with short cuts. I also posted a step by step to replace the passenger side (with pics) on this forum. The drivers side took about 1 3/4 hrs and the passenger side only an hour. Not hard at all. I am NOT a technician, but a shade tree guy. Computer guy by trade.
The following 4 users liked this post by fblonk:
CamelKool (08-09-20), Doublebase (03-07-17), Parrokeete (02-11-22), Rajananda (02-05-22)
Old 11-18-18, 11:26 AM
Lekeith1
Lekeith1's Avatar
Default 2007 ls 460 lwb
Hello I'm new to this forum. I just bought a 2007 ls 460 lwb with 105,600 miles 1 owner from a dealer in sharon, ma. Today I noticed small drops on my garage floor. I put down some cardboard and freaked out when I saw a spot of what looked like oil. It's the 5th day of taking posession of the car, what should I do. take to local dealer or what. I checked the oil and it's full engine coolant is low tho. I'm lost yall please help me..
Old 11-19-18, 09:27 AM
213374U
213374U's Avatar
Have you tried finding out where it's coming from like the OP to this thread did? Either take a look for yourself or get it to someone who can (who also isn't a dealership) and figure out where it's coming from. Can't help you until that's done.
But, if you just bought the car 5 days ago I'd go back and ask if they could take a look. Assuming it's not a buy-here pay-here lot that gave you a sweet >15% interest rate on your loan I'd guess they'd be happy to at least diagnose it for you at no cost.
Old 11-19-18, 01:08 PM
Lekeith1
Lekeith1's Avatar
This is what the dealer told me today: I spoke to my General Manager and Pre-Owned Director, Don Xu, in regards to your 2007 LS. Because you are 5 hours away, please bring your LS to the closest Lexus dealership in your area to have a diagnostic run to see what is leaking and where. Do not have them complete any work on the car, please let us know what the find during the diagnostic find and what the cost is to fix it.
Old 11-20-18, 09:14 AM
213374U
213374U's Avatar
Sounds like the right course of action and that they may be willing to work with you. Good luck
Old 11-20-18, 10:53 AM
Lekeith1
Lekeith1's Avatar
I'm still under my 30 day warranty aswell. I will keep the forum posted
Old 03-04-20, 06:44 PM
Pronto86
Pronto86's Avatar
Default Driver side valve cover removal on 07 ls 460! Can’t get to the bottom bolts
Need help ASAP
Old 03-05-20, 09:31 AM
213374U
213374U's Avatar
Only help I can offer with that post is to take some time to check out a few threads and deduce how to make a post that will get you the answers/help you're looking for. Good luck!
Quick Reply: oil leak on LS460 L
