Rust on the inside steering shaft?
Old 12-11-12, 05:13 PM
lexus600hl
lexus600hl's Avatar
Default Rust on the inside steering shaft?
As you can see in the picture below, there is rust on the joint..
I have two idential 2008 LS 600 HLs. Only one has rust on the joint. Both have rust on the bracket on the left..
It seems unusual that Lexus would have rusted parts on the inside, so quickly.
None of us would think of checking it. The location is above the accellerator pedal, under the steering. I saw it accidentally, because someone asked me to take a picture of the two buttons in that location (one turns pcs off and other is for TPMS).
Wondering if anyone else has rust in the same locations.
Here is the link to the picture
https://www.clublexus.com/forums/mem...s-edition.html
Old 12-11-12, 07:59 PM
SBlexus
SBlexus's Avatar
Yeah I saw that when I looked at your pic. It look like someone used a heavy degreaser when they detailed your interior or cleaned the carpets. That's what I was thinking.
Old 12-11-12, 09:18 PM
Lextrician
Lextrician's Avatar
surface rust correct? depends on the material used, can put some stop rust on it or never dull it.
Old 12-12-12, 04:55 AM
lexus600hl
lexus600hl's Avatar
good point! It must be related to carpet cleaning!
Old 12-12-12, 04:56 AM
lexus600hl
lexus600hl's Avatar
whats a good rust stop? I just put wd-40 on it..
Old 12-12-12, 11:32 AM
Lextrician
Lextrician's Avatar
probably (CLR) there are others that you can find in walmart, nothing that will stop rust. but something that will neutralize it.
Old 12-12-12, 11:44 AM
dengman
dengman's Avatar
looks like its not coated with grease or oil. Most likely its not stainless steel either. Just surface rust. Unfinished metal would do that over time. oxidation of steel.
I would CLR or rust converter or leave it alone.
Old 12-12-12, 04:16 PM
lexus600hl
lexus600hl's Avatar
i had someone sand it down and oil it. It looks perfect now.. It was just surface rust.. as someone said, probably from detergents of carpet cleaning.. Even then, I am some what surprised.. lexus should be using better metal!
Old 12-12-12, 06:31 PM
Lextrician
Lextrician's Avatar
limited choices as you want it to be strong yet lightweight, unless it is polished then cleared aint much can be done as iron and steel will get surface rust but will not affect the integrity.
IS250TW
07-17-20 12:11 AM
Sumondra
07-19-18 10:16 AM
gs-ireland
07-31-15 09:32 PM
sam12345
04-25-14 07:05 AM
lexpure
04-15-11 05:14 PM
Quick Reply: Rust on the inside steering shaft?
