Know anyone to do 2007 LS 460 headlight replacement?
Old 03-15-16, 06:26 PM
  #46
tridge400
tridge400's Avatar
Default 2008 LS 460 Low Beam Bulb Replacement
Taking the wheels off gives you so much room to remove the liner for access. I purchased Phillips D4S bulbs from Amazon for $49 a piece .It took me about an hour doing the passenger side and 30 minutes the drivers, clearly i was more trained after the first side...what was cool was for 100 bucks and about 1.5 hours, it was done. I also took the time to inspect the brakes and suspension hardware for any damage or wear. But the real kicker was after calling 3 dealers in my area about the cost of performing this maintenance and the quotes i got $903.00, $730, and $520. It really felt good to keep the dollars in my pocket. If you have the time, do it yourself.....it is really easy and you will pat yourself on the back.
Old 02-02-18, 09:38 PM
  #47
RandyV
RandyV's Avatar
Originally Posted by kentserph
Hi Guys,
I just replaced both of my HIDs in about an hour without removing the wheels. You can check out my YouTube video here:
HID Bulb Replacement - 2007 Lexus LS460L - YouTube
Hope that can help some of you out there.
Nice.
That's tomorrow's task.
Old 02-05-18, 09:10 AM
  #48
R Z
R Z's Avatar
When my drivers side light went out, I thought about trying it. But I wasn't up to the task. A friend did it for me. As mentioned, it took about an hour to do the passenger side first. That's because he couldn't figure out how to clip in the thin wire clip. But the drivers side went fast. I will say that not removing the wheels made it tougher, plus my fender liners aren't quite the same any more. But, I have light!
Old 02-16-18, 08:37 PM
  #49
ICharles85
ICharles85's Avatar
Default Any suggestions on replacing oxidative interior Headlight that 2007 Lexus LS 460
Old 02-16-18, 08:42 PM
  #50
ICharles85
ICharles85's Avatar
Originally Posted by Vo707
I LOVE THIS FORUM.... I will try this when I get home THANK YOU
Is it recommended to change out the ballast as well?
Old 02-16-18, 08:44 PM
  #51
ICharles85
ICharles85's Avatar
Originally Posted by Tee
You have to remove the wheels and then the fender lining to replace the bulbs. This is how the service manual shows replacing the bulbs, use a flat head to remove the liner tabs. You can do it, might take you 20 mins ea good luck.
Is the ballast recommended to be switched out when replacing the HID lights?
Old 02-17-18, 12:34 AM
  #52
k311in
k311in's Avatar
No you don't need to replace the ballast
Old 02-17-18, 03:37 AM
  #53
ICharles85
ICharles85's Avatar
Thank you k311in
Old 01-07-22, 07:35 PM
  #54
Parrokeete
Parrokeete's Avatar
Originally Posted by qh0st
Thanks guys. I'm really have trouble removing the fasteners. I was able to remove the fender screws with a flat head screw driver (ended up breaking one btw). But after that, how do I get the fastener off so I can pull the liner?
Buy yourself a set of fastener clips that come with a clip Tom over tool the resembles a screw driver it works well and if you end up breaking a clip or two you can replace it from you kit.
Old 01-07-22, 07:40 PM
  #55
Parrokeete
Parrokeete's Avatar
Originally Posted by bonafyd
Not taking anything away from Tee but you don't have to remove the wheels or the entire liner.
Just turn the wheel in the opposite direction of the light your gonna change,remove the fasteners & you'll see the light covers.. I did it a few times already trying to decide on which bulbs to run lol..
What bulb seems to be good to replace a front running light bulb with?
Also is there a way to replace a burned out small bottom bulb on the front headlight?
lexusisgs
10-29-20 11:35 AM
JamesG
07-05-13 10:14 AM
LuxuryGS3
08-08-12 09:28 PM
marcoes300
02-10-11 03:20 AM
tvd51
Lighting
01-18-04 01:29 PM
Quick Reply: Know anyone to do 2007 LS 460 headlight replacement?
