How to install to LS430 through car harness
I want ti install my ipad into my car system so i need to know what the exact devices needed for this project
i saw some videos but i got confused my car had AMP so I want to know do i need to replace it with new one or just insert the new one through the car harness
check this video they use Amp
do i need to do the same ??
how can i connect the Amp to car harness?
how to connect the Ipad to the Amp and what i need for that ?/
can some one give the wiring diagram to make this project easy ?
waiting for support
thanks
waiting for support
thanks
Not sure about the direct connect method, but you can install a VAIS Tech unit which interfaces with the factory radio and allows you to run the Ipad through the vehicle audio.
http://www.ebay.com/itm/272092911666...%3AMEBIDX%3AIT
Thanks
but does it connect directly from the harness & to the Ipad
also will a VAIS Tech unit fit inside the dash ??
Also i want to install my ipad on the dash with removal of the factory head unit so
like what he does in this video because my LS430 does not have Screen or navigation just CD changer
so i want to install my ipad in the dash
KC100
04-01-12 03:30 PM
