driver window glass rubber weatherstrip
The weatherstrip which covers the top of window frame. the lil drip edge is peeling. Anyone know the part number for 2004-2006. Thanks be well Warm
# 75531-50040. http://www.lexussouthatlantaparts.co...553150040.html
Some windshield installers use a plain black plastic/rubber molding, Warm. There's a thread about it.
Also, here are all four part numbers, if you need them:
Front Driver: 67864-50030
Front Passenger: 67863-50030
Rear Driver: 67888-50030
Rear Passenger: 67887-50030
Both fronts have two clips at the bottom that fasten them down. I broke all but one. Save yourself the headache and order some of these replacement clips (two per each front stripping): 90467-08219
Yes, this is the "upper" stripping that seals the gap between the door and the body of the car. It was the first project I did to mine after I bought it. The upper stripping was pealing on all four doors. This was a super easy repair. I've attached an image of the stripping in question.
Upon removing the clips a bit of soapy water and the seal slips out then the reverse? Starting from which end worked best for you?
Thanks for the heads up
Doug k
Marc,
Thanks for info on this one, and especially the comment about buying the replacement clips for the fronts.
I bought a set of four strips (and four clips) from Lexus of South Atalanta (www.lexussouthatlantaparts.com), and installed them on my 2005 LS430 today. Took about 2 hours, although the project also involved the usual extra stuff (cleaning, application of Mother's Back-to-Black on the all the door sills and doors, etc.).
The replacement clips for the weather stripping seem to be part no. 90467-05157 and not 90467-08219.
$36 - Front Driver: 67864-50030
$36 - Front Passenger: 67863-50030
$0,88 - Cips 90467-05157 (2 clips needed for each side)
$74 - Rear Driver: 67888-50030
$74 - Rear Passenger: 67887-50030
$0.88 - Cips 90467-05157 (2 clips needed for each side)
jasone36
03-21-12 07:07 AM
Philly#1 Lex
SC- 1st Gen (1992-2000)
11-21-06 08:49 PM
