Timing Belt & Water Pump Kits
Can someone tell me what the difference is between these 2 kits (the first one is $73 more):
https://www.amazon.com/AISIN-Timing-...2%3A1248861011
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
AND I found this one on eBay that is MUCH cheaper (are GMB parts low quality?):
http://www.ebay.com/itm/98-09-Toyota...pRnkzJ&vxp=mtr
Use this OEM kit >https://www.amazon.com/Aisin-TKT-021...iming+belt+kit
It's also less expensive than the first one you list. It contains everything you need. The first kit you list doesn't have the belt tensioner - yet costs more.
When I changed mine I bought the whole kit including crankshaft seals and camshaft seals if you plan on keeping the car pay a little extra for the piece of mind and do the whole kit.
Doing the cam seals requires a LOT more work. The camshafts must be removed. If you can DIY, great. How many miles on your LS? Cam seals don't typically leak for at least 200K+ miles. My '01 with 275K miles is on original cam seals. How long do you plan to keep car? If this is your first timing belt change, doing cam seals is probably unnecessary.
Ah, ok. Good to know. It's my first Lexus, a 2004 430 with 123k miles. The last service I see completed was the 60k. So I figure timing belt, water pump, spark plugs, and oil change should have it in good shape. I definitely not a DIY'er, never worked on an engine before. I could probably pull off the oil change. It's got new brakes and tires, not sure about rotors, will find out. Any other suggestions?
billydpowe
04-09-15 08:48 PM
BeaksSC
Performance & Maintenance
27
11-28-14 07:59 AM
brock125
12-22-09 09:43 AM
