Timing Belt Change - Forgot to Use Loctite
…on the tensioner pulley bolt. I've got the car pretty much put together except for installing the radiator and filling it with antifreeze. How much of a real issue is this (not applying loctite blue to the threads of the tensioner pulley)?
Wish I could help with that question, but I haven't done my timing belt replacement research yet and I need to collect all the tools to be able to do it by next year possibly. If you know of a good resource for doing that job I'm all ears. Sounds like you may have just done your first one, so I hope it worked out for you!
The factory DOES use this product on the Timing Belt Idler Sub-Assy No.1 pivot bolt. The adhesive specified is part # 08833-00080, or THREE BOND 1344, or LOCTITE 242, or equivalent. Apply to 2 or 3 threads of the bolt, then torque using a 10mm hex wrench to 25 ft*lbf / 34.5 N*m.
As to answer the question of what could happen by not applying adhesive, I don't have a solid answer. I can only speculate that Lexus engineers deemed it theoretically possible for the bolt to become undone even at the specified torque, and that specifying a higher torque would damage something or otherwise not be helpful.
Update. I called our service advisor at the local Lexus dealer and asked her to inquire to one of the techs whether or not they use a thread locker on the tensioner bolt. I was surprised to learn that the techs, as a matter of standard procedure - DO NOT use a thread locker on the tensioner bolt.
So, I mentally wrestled with whether I should tear it back down or leave it alone. In the end, I decided to tear it back down and apply loctite to the tensoner bolt.. Fortunately I had not installed the radiator and added coolant, so I was able to get to the tensioner bolt in a short 30 minute interval. Another hour and a half later I had it buttoned back up to the point where I was when I started. All I've got left to do is install the radiator, thermostat and fill it up with coolant. So, regardless of what the techs do, I decided to make it right so I can rest in the assurance I did it right. YMMV.
YODAONE
02-06-17 02:02 AM
