Got one headlamp replaced, now car looks odd. Any way to clean up old one?
Old 08-03-15, 08:32 PM
LuxuryGS3
LuxuryGS3's Avatar
Originally Posted by SW15LS
You need to polish the lenses out after sanding them, just clear coating them after that is whats giving you your cloudy appearance.
Done properly, it should look pretty darn close to the new lamp.
This.
After wet sanding you will have to polish it with a compound and then move to a finishing polish. You can purchase a buffer like the PC 7424XP or even the 3" Griots Garage Buffer to use for restoring the headlights and then you could do a few friends lights for some $$$ and get your money back within 3-4 cars.
Old 08-03-15, 08:41 PM
Received 2,714 Likes on 2,299 Posts
Wet sand then use this to protect the lens. The paint is a 2-part system and will cure and not yellow and will not be affected by chemicals or UV.
http://www.spraymax.com/index.php?id=361&L=1
www.youtube.com/watch?v=9HEIwqCMtJ0
Old 08-04-15, 08:39 AM
mikevanle
mikevanle's Avatar
I will try to polish out the headlight as is and see how it looks. If it's still too off, I'll go back and wetland it again (probably to the point of taking off the current clear coat?), polish, then clear coat.
Old 08-04-15, 11:14 AM
swfla
swfla's Avatar
Received 1,209 Likes on 956 Posts
Yes, you'll need to wet sand off the clear coat. Then polish really well, then clear coat again.
Old 08-05-15, 12:08 AM
KING
KING's Avatar
Be sure to take your time, and start with low pressure, then climb to higher pressure.
I had to spend 30 min. per headlight to finally get some good results.
And one thing that is a MUST! Get a drill bit with the polishing rag on the end, like the one Meguairs have in their kit. Because I promise you, without it you will never get satisfying results, let a lone match a brand new headlight.
Old 08-05-15, 07:38 PM
ancdmd
ancdmd's Avatar
My lenses were a real mess, I used the 3M kit that came with a pad you mount to a drill and several sanding and polishing discs. My lenses required a pre-sanding with 400 grit sandpaper they were so bad. I found the key is spending a little more time than you think with each step so make sure you've removed all the previous grit's scratches. The lenses looked new when I was done with the polishing.
I then had them covered with a Suntek PPF (clear protective film) that really gives them optimal clarity and excellent protection from further scratching and hazing.
Old 08-09-15, 02:05 PM
BigBruiser
BigBruiser's Avatar
Two years ago I used a product called Crystal View($25 from Amazon). I've used it before. After I used the product I had 3M protective film applied and my lights still look good.
I prefer Crystal View because I researched the final liquid coating you apply after buffing it and discovered it was the same liquid coating used in outdoor signs to prevent UV fading!
Amazon.com: Headlight Restoration Kit/Defogger: Automotive Amazon.com: Headlight Restoration Kit/Defogger: Automotive
These pics are after 24 months of driving, non-garaged and about 68k more miles of mostly highway driving.
Old 08-12-15, 05:01 PM
lexusls4
lexusls4's Avatar
Default hazy headlight
My brother used bug spray on his Honda oddeysey headlight and they look amazing . I didn't believe him but I didn't think he would lied to me..you can try it on a diffrence car first but the only thing I didn't like was it felt tacky to touch.
Old 08-12-15, 05:09 PM
Received 2,522 Likes on 1,820 Posts
The bug spray won't last.
Old 08-13-15, 07:02 AM
KING
KING's Avatar
Bug spray will eat through the plastic, it will do more harm than good.
axis77
04-11-16 10:24 PM
LiLS
Automotive Care & Detailing
01-07-11 01:01 PM
DrRick
19
04-28-07 10:02 AM
Slick Lex Coupe
SC- 1st Gen (1992-2000)
03-04-01 06:48 PM
Quick Reply: Got one headlamp replaced, now car looks odd. Any way to clean up old one?
