New 2003 Fuel cap and P0430 code.
Old 07-08-15, 09:14 AM
MadBlax
MadBlax's Avatar
Default New 2003 Fuel cap and P0430 code.
Hi guys,
Just picked up a 2003 LS430 with 180kms or 111,000 miles on it.
When I first looked at it the check engine and and vsc light were on, I know the vsc comes on when the check engine does. So I got a scanner went back scanned it and got code P0430, which is a exhaust/cat. Also got an incorrect fuel message. I asked the previous owner if he had premium in it he said yep. So anyhow I knocked him down a bit on price and bought it, as I could not hear any leaks, and it was just to clean for a Canadian winter driven car to pass up.
So after I got it home I threw it up on some stands, to swap out the wheels, crawled underneath still couldn't hear anything. Before that I removed and re tightened the fuel cap, set the car down and fired it up, no check engine light and vsc good. Could it have been just a loose fuel cap, or should I still run it over to a muffler shop to check for leak or crack?
Thanks for any replies.
Old 07-08-15, 10:29 AM
doodoo
doodoo's Avatar
It maybe be the gas cap. Could also be a leak near the o2 sensor in the rear. I can't remember passenger or driver side. The exhaust pipe may have a hole/leak hidden by the shield covering over the y pipe.
Old 07-08-15, 11:13 AM
Tom57
Tom57's Avatar
Yes, it could definitely be a loose or ill-fitting gas cap. Don't do anything now since the CEL went off.
Old 07-08-15, 02:30 PM
MadBlax
MadBlax's Avatar
That's exactly what I am thinking, leave well enough alone and enjoy this car.
burbank
07-14-16 02:37 PM
akafixture
02-10-16 02:12 AM
areukhmer
01-14-11 06:27 AM
larryhorne
GX - 1st Gen (2004-2009)
03-28-10 12:05 PM
Ariyanna
01-19-10 09:42 PM
Quick Reply: New 2003 Fuel cap and P0430 code.
