"check vsc & trac off" lights on after installing airlift v2 management
I recently bagged my 01 LS430. I'll post pics later when I have high res shots...
Anyway, the problem is that my dash lights "check vsc" & "trac off" came on after installing the management only. I had a problem with strut bag connectors, so I was still on my stock suspension until completely finishing air setup a week later.
The car ran like it should on stock suspension with v2 lines installed, just the lights came on. With bags installed, the car still runs fine. Just the damn lights.
So the lights still come on. The air install is complete. I already tried to jump pins in OBD2 scanner connector because that was supposed to be a DIY fix I found on the forums. I tried many times and many different ways.
Does anyone have a clue as to what is causing lights to come on?
Any feedback is appreciated. Thanks!
