LED Daytime Running Light project
Old 04-02-14, 04:09 PM
  #31
LEX ES300
LEX ES300's Avatar
Originally Posted by ultm8mind
ES300, appears with how small of a strip you have you could actually still put them in the OEM fog housings and it'd probably look better. But that's just my 2 cents...
Yeah I totally know what you mean - I'm about 90% happy with the outcome. I did think about trying to incorporate them into the fog lights to hide them but I have nice white HID fogs anyway. I would have had to remove the foglights, put them in the oven and bake them open to fit anything else inside it. I didn't want to risk ripping things apart, messing with wiring too much. Plus the foglights are naturally curved in shape meaning the light wouldn't have been completely forward facing. I thought about strip leds but there're just not bright enough and can look really cheap. It's hard to see from the pics but my DRLS are recessed in the vents so when you stand next to the car they don't stick out too much.
Old 07-01-14, 06:51 AM
  #32
greg s
greg s's Avatar
Old thread bump.
Check out my p-shop skills. Has anyone installed DRL LEDs in the areas i have shown in this pic? I'd love drl leds but i'd like them to be more oem looking.
Old 07-01-14, 09:58 AM
  #33
denIS200
denIS200's Avatar
My DRL in place :
Denis.
Old 09-24-14, 09:52 AM
  #34
chunkyda
chunkyda's Avatar
So if you disable the factory DRL how do they turn on? Manual switch?
Old 09-24-14, 09:08 PM
  #35
Lavrishevo
Lavrishevo's Avatar
You need the Techstream software and a mini vci cable to turn them on and off.
Old 09-24-14, 11:31 PM
  #36
tcr101
tcr101's Avatar
Originally Posted by Tom57
I was looking at the same Techstream, but it won't work with 64-bit operating system.
It does work with x64 architecture. You just have to install drivers via command prompt. I wrote it somewhere in that techstream thread.
Old 09-25-14, 07:54 AM
  #37
chunkyda
chunkyda's Avatar
Originally Posted by Lavrishevo
You need the Techstream software and S mini vci cable to turn them on and off.
My question is, once you disable the factory DRL which is a dimmed high beam, how do your LED aftermarket DRLs turn on when the ignition switch is in the ON position?
Old 09-26-14, 10:48 AM
  #38
Lavrishevo
Lavrishevo's Avatar
Unless you rewire the setup for the fog lights they will not turn on without the headlights on. I have been thinking about the HID fog light upgrade but it just throws light all over the place. Sure it's a lot brighter but its actually rather inconsiderate to other drivers. I know a lot of people don't care but I do.
I still have not moved my Phillips kit. I have been so busy and it's going to be a pain to do. They are not in the ideal location but surprisingly I have received quite a few compliments and people asking what they are. One of these days I will remove the wheel well covers and mount them at the air vents for the brake ducts. Or maybe another location. Not sure yet. I also like how the Phillips kit does not require a on / off switch. It detects when the car is running and turns on and off via voltage from the alternator. They are nice units.
XCLSVELS
12-26-19 08:36 AM
matthew99
10-02-17 09:16 AM
Choosy
11-14-16 09:25 AM
Titanjose
HS 250h Model (2010-2012)
03-29-11 05:55 PM
MLevinson
07-15-08 08:11 PM
Quick Reply: LED Daytime Running Light project
