Info on Map Light bulbs
Old 02-18-14, 04:11 PM
toyo
toyo's Avatar
Default Info on Map Light bulbs
The manual does not state the bulb size for the front map lights, nor do any online catalogs. To save some of you guys the headache of what bulb it is I figured I would help. It is a BA9s type bulb. Hope that helps. I am in the process of swapping all my lights over to LED as I find them very beneficial.
Old 02-18-14, 04:34 PM
LiCelsior
Retired
LiCelsior's Avatar
haha good thing they are in this FAQ thread, https://www.clublexus.com/forums/ls4...nd-part-s.html
Old 02-18-14, 04:35 PM
KING
KING's Avatar
Will you realize a huge difference?
And which bulbs do you exactly mean?
Old 02-18-14, 04:38 PM
toyo
toyo's Avatar
Actually they are not listed. It gives you the dome lamp which is the Festoon type. Can you please point me to where you see the Map bulbs?
Old 02-18-14, 04:40 PM
toyo
toyo's Avatar
It is a huge difference between the factory or incandescent bulb. I already changed the dome light and it is a huge difference. I will take a pic for you to compare.
The exact bulbs I am talking about are the map lights in which you push the button on each side of the dome lamp.
Old 02-18-14, 05:19 PM
LiCelsior
Retired
LiCelsior's Avatar
LEDs are a lot brighter than the oem bulbs in there. I did a full LED conversion also using the guide above. beats opening them up individually and trying to figure them out. 16 led boards all around
no problem man, it was in the first post.
Originally Posted by RomanTPA
Map Lights: BA9S 1895 T4W
Old 02-19-14, 10:35 AM
TaninAuto
Sponsor
TaninAuto's Avatar
We have full LED kits for the LS430.
We also have the BA9S LED's for $2.99 each.
http://www.taninautoelectronix.com/B...LED-p/ba9s.htm
And the festoon LEDS
http://www.taninautoelectronix.com/F...estoon_led.htm
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
Old 02-19-14, 11:18 AM
ACleanSC4
ACleanSC4's Avatar
I did these to mine...sooo bright...
Old 05-01-15, 12:56 AM
VanCityLS4
VanCityLS4's Avatar
Are the rear map lights BA9 as well ??
Old 05-01-15, 07:15 AM
Legender
Legender's Avatar
I'm in the process of switching out the lights on my LS400... and yes, they make a huge difference...
I believe the rear reading lights are the 194 version that simply push in.
CarlitoIS
06-05-16 11:51 AM
jhs82
09-07-13 03:17 AM
jameshtx
Lighting
06-19-12 01:24 PM
KeepDaBeat
RX - 1st Gen (1999-2003)
09-05-06 04:03 PM
Quick Reply: Info on Map Light bulbs
