Do I need a Youzealand SS Kit Pro? (w/ pic of my car)
'04 UL on 21s w/ datasystem controller. I put it on "L" and this is as low as it gets (all four fenders are shaved and nothing is touching in the front that would stop it from going lower). I want the front to be about an inch lower to match the look of the rear.
Do I need the SS Kit Pro? I did do a search and could not find a clear-cut answer and really just wanted to check with you guys before spending $2k after install or whatever it will be, even if someone gets upset at me for asking such a noob question.
Here is my car with the SS Kit (non-Pro) using Datasystems on L and 21" DTX. You can see the front wheel pushed back, which caused rubbing inside the fender. You'll be lower about 10mm when dumped. The Pro version will fix that caster issue.
poorbong
05-08-10 08:09 AM
