PLS help no idea what happen
Old 06-13-13, 02:30 PM
VIPDrizzy
VIPDrizzy's Avatar
Default PLS help no idea what happen
today when I got in my car I saw the warning indicator that said check VSC however I don't really know why that would have come on the check engine light is on is well and it doesn't seem to go off the car drives fine but the VSC button is no longer functions any ideas....
Old 06-13-13, 03:22 PM
BMW7_LS430
BMW7_LS430's Avatar
Check tire pressure. Just one of the possible reasons.
Old 06-13-13, 04:17 PM
Jabberwock
Jabberwock's Avatar
After checking tire pressure and making sure gas cap is on and tight, you will have to go to dealer, independent shop, auto zone etc and have the error codes read
Old 06-13-13, 04:20 PM
LsBanGer43
LsBanGer43's Avatar
Check your battery connection could be loose
Old 06-13-13, 04:34 PM
amillion
amillion's Avatar
Check gas cap or replace it...
Old 06-13-13, 05:44 PM
Lynzoid
Lynzoid's Avatar
that cracked me rrriiight up
Old 06-15-13, 05:05 PM
VIPDrizzy
VIPDrizzy's Avatar
well i guess it wasn't an issue i looked it over all day and found nothing the light is off as well as the check engine light....i guess thanks for the help guys
Old 06-15-13, 05:09 PM
yuri.ber
yuri.ber's Avatar
This could be the first sign of one of the oxygen sensors going bad. Warning lights could come back area days to a week later. Check the error code, most likely it's an O2 sensor.
Old 06-17-13, 07:59 PM
Slvr surfr
Slvr surfr's Avatar
Could be the beginning of a small exhaust issue. I had one of clamps that's attached to the y-pipe come off causing a leak. Not know it was a clamp that fell initially, i attempted to seal it with some exhaust tape to no avail. After further inspection and comparing that one pipe to the other side i seen that it was a clamp missing. Went to Autozone and bought a $3.00 clamp and no more leaking, bad sounds, and no more VSC, CEL, and red triangle. Get an inspection done.
Old 06-17-13, 10:25 PM
Bocatrip
Bocatrip's Avatar
The most common issue with your symptoms has been one of the oxygen sensors.
Old 06-18-13, 12:13 PM
InfamousLS
InfamousLS's Avatar
It def sounds like an O2 sensor issue. I'd anticipate it going again, it's real temp sensitive.
Still don't understand why VSC goes off when LSs blow o2 sensors... If anyone has an idea I'd love to know.
Jeffrimerm
02-13-14 03:42 PM
snayger
04-22-13 07:33 PM
kasper612
01-22-12 04:30 PM
jimboNmia
01-18-10 01:26 PM
kidluvsole
05-26-08 07:32 PM
Quick Reply: PLS help no idea what happen
