Offset Gurus please Help!!
Old 02-19-13, 05:41 PM
LethalLS
LethalLS's Avatar
Default Offset Gurus please Help!!
I found the wheels I want they are HRE 549's 19x8 but they are a 5x112 bolt pattern, go figure. My 2 options as I understand them are adapters or re-drilling them. My worry with the adapter is I can only find adapters that are an 1" thick (25.4mm) and the wheels offset is already +39, will they fit with a 235/35/19 front tire and 235/40/19 rear tire? As far as re-drilling I really have no idea what my options here are except maybe sleeving the wheels or just making the original hole bigger considering they are hub-centric wheels I would just need more room to tighten them down.
Old 02-19-13, 05:50 PM
LethalLS
LethalLS's Avatar
I apparently have a 3rd option, Variation Lugs?? Anyone used these or know where I can get them. Apparently German wheels are drilled for 14mm studs but our cars use 12mm studs and you can use these bolts with no wheel modification is needed.
Old 02-19-13, 06:09 PM
bootnylee
bootnylee's Avatar
go into wheel fitment thread.. sounds like more of a headache to me ... I'm still trying to figure this stuff out
Posted from ClubLexus.com App for Android
Old 02-19-13, 06:45 PM
LethalLS
LethalLS's Avatar
According to all of the searching I have done these variation lugs work great for 5x112 wheels on our hubs, specifically HRE and Mercedes OEM wheels.
Old 02-19-13, 08:36 PM
SQuester
SQuester's Avatar
Wobble lug nuts work fine for 5x112 to our 5x114.3
Old 02-20-13, 06:22 AM
bootnylee
bootnylee's Avatar
Thumbs up
You are a cool cat!
Old 02-20-13, 07:08 PM
LethalLS
LethalLS's Avatar
SQuester, do I need hubcentric rings even if the rims are hub centric?
Old 02-20-13, 07:11 PM
LethalLS
LethalLS's Avatar
Disregard about the rings, I need them. I guess I should've googled that one first.
Old 02-21-13, 06:02 AM
SQuester
SQuester's Avatar
If the rims are hubcentric, meaning the rims center bore is the same 60.1mm as our hub bore, then no you don't need(and couldn't even install) hubcentric rings. With "tuner" lug nuts, your rims will also be "lug centric".
ISF001
RC F (2015-present)
73
11-09-19 05:00 PM
grootds17
CT 200h Model (2011-2017)
10-12-17 07:29 PM
Robles84
09-15-16 12:50 PM
ceegeeaye
Wheels, Tires & Brakes Forum
02-23-12 05:29 AM
yellowssm
03-01-06 12:11 PM
Quick Reply: Offset Gurus please Help!!
