5th wheel spare question
Old 03-06-12, 08:55 AM
sellshomes
sellshomes's Avatar
Default 5th wheel spare question
When you guys get new wheels for your car in a different size from what you have, do you get a 5th wheel for the spare or just hope you don't get a flat tire?
Old 03-06-12, 09:16 AM
sojah
sojah's Avatar
FIRSTS
if i get a flat i slap the spare (stock wheel) back on until i get it fixed.
Old 03-06-12, 09:48 AM
VNN326
VNN326's Avatar
apply for AAA.
Old 03-06-12, 10:55 AM
Boomer01
Boomer01's Avatar
Even though people get larger diameter wheels, the sidewall will be thinner than the factory ones and the overall diameter of the wheels/tires should be the same or close. You could use the spare with no problem.
Old 03-06-12, 12:06 PM
hiimphilll
hiimphilll's Avatar
The KEY thing is to have the proper lugnuts for your OEM spare when you do get a flat. I am assuming you are going with aftermarket wheels . I wouldn't worry too much if the OAD is slightly different. My OEM spare has never been used on my '03... the tire manufacture date is 2002
Old 03-06-12, 01:36 PM
sojah
sojah's Avatar
oh yeah very important point that i learned the hard way one day on the side of the highway. my tuner lugs did not hold on the stock wheel/spare so i was assed out literally on the side of 495 now i carry 5 stock lugs with me always
Old 03-06-12, 02:00 PM
GR6RR
GR6RR's Avatar
Spare tire with spare lugs! Now thats a good reminder.
Old 03-06-12, 02:12 PM
sellshomes
sellshomes's Avatar
Cool, thanks, didn't want to buy a 5th wheel and another tire to boot.
Hell, I guess people drive on donuts so didn't think it would have mattered much anyway.
Its my kids car, and we all have AAA.
I will make sure to keep the lugs for the spare 17" wheel but I think they are the same since its a Lexus wheel copy of the OEM 18" wheel and only a bit larger.
Old 03-06-12, 03:00 PM
sojah
sojah's Avatar
also need to make sure you custom trunk sub box isn't made from the inside out and that you can't get it out if you get a flat. learned this one dark night around 2am in PA as well
Old 03-12-12, 12:46 PM
Quipper
Quipper's Avatar
You know, I've been driving for about 25 years and have never once had a blowout! Just blessed, I guess.
Old 03-12-12, 08:00 PM
Jabberwock
Jabberwock's Avatar
I had same experience until about 3 years ago and since then I have had about 4 flats while driving - all due to nails/screws or sharp metal debris on the road. I was super lucky for my first 35 years of driving I guess.
Anyway I was shocked at how much heaver a current wheel/tire is on a modern car than those 1960's era 13-14 inch wheels (I was also a little younger and stronger). The last one occurred in the heat of last summer here in DFW, thought I was gonna have a heart attack getting the spare back on the hub and bolted down in the July afternoon 99 degree heat.
If you are not in fairly decent shape and you have a flat its likely better to call a tow truck.
Old 03-13-12, 06:26 AM
01LEXPL
01LEXPL's Avatar
This.
I have both sets at all times for this reason. Winters are OEM rims, so bigger lugs [in a box in the trunk] and summer's require thinwall 'tuner lugs' [FTL], had a blowout a couple years back running over some debris falling from a dump truck
Ran on the spare for a week or so.
Old 03-13-12, 06:36 AM
jayclapp
jayclapp's Avatar
When I scuffed one of my chrome wheels I purchased a replacement and put the scuffed wheel in the trunk. No problem or embarrassment when I get a flat!
Old 03-17-12, 06:53 PM
yuri.ber
yuri.ber's Avatar
I had my front right 18" wheel busted about 4 months ago, put on a stock 17" spare that was in the trunk and drove for two weeks with no issues at all.
IMHO to have a stock spare while having different wheels on car just makes you repair a flat faster since the looks are weird.
Old 03-17-12, 11:09 PM
spin420
spin420's Avatar
I don't even have a spare at all! My air system, amp, and sub/ported box takes up so much space!
I think I should sign up for AAA.
galmonte86
01-18-16 04:26 PM
olivelexus
08-12-10 10:04 PM
Coconut
04-05-09 09:58 PM
Mesca
Wheels, Tires & Brakes Forum
11-27-08 06:49 PM
Bobby D.
07-31-05 12:16 AM
Quick Reply: 5th wheel spare question
