well that didn't take long
Old 03-30-10, 09:46 PM
aslowdodge
aslowdodge's Avatar
Default well that didn't take long
I've had my 2002UL car for 5 days and apparently blew the subwoofer in the ML. I hear lots of rattles out of the back now. Funny thing is I don't think I push it that hard.
So I've checked other threads. There's always the cheap silicon fix, but is there another " bolt in" replacement subwoofer you guys are happy with?
I read the "here comes the boom" thread.
So is the subwoofer supposed to be 4 ohms? 2 ohms?
Someone suggested replacing the Levinson amp with a aftermarket better amp, but someone else said the Nav needs the factory amp to function.
Help . . .
Old 03-31-10, 05:40 AM
Boomer01
Boomer01's Avatar
I think that the oem sub is 12 ohm which is very odd. You do need the factory amp but can use a line-out converter to run a seperate amp off of it to power a seperate aftermarket sub.
Old 03-31-10, 06:28 AM
Lust4Lexus
Lust4Lexus's Avatar
Help . . .
If i were you, I would do the silicone fix. Why? Because it does not sound like you "need" alot of bass. You "don't push it" so going through all the trouble of replacing the stock sub with something aftermarket may not be worth the trouble. The LS setup is one that is made for SQ. IN SQ cars in competition, one of the most desirable attributes is the blending in of the subwoofer. And when you have a perfect blend, you cannot tell you even have a sub running in the trunk. and all the bass imaging comes from the front. IMHO, the ML system, with all it's faults, still does this pretty well, with it's given drivers.
Now, the Sub is 12 ohms, ( have not confirmed this myself, but thats what we have heard) and this is not the simple plug and play specification. Sure, another sub with the same ohm rating will work, BUT, if using the ML amp, how about it's sensitivity rating? Is it free air? If it's 3db more or less, you are either going to have a blaring sub, or one that barely compliments the rest of the frequency band.....and who the heck wants that? You could go all out and get another amp and sub and stick a nice little sealed box, and stick it in the trunk, but that would be my only option, because the other option of switching out woofers is going to be more of a hassle than it's worth. I vote for silicone.
Old 03-31-10, 12:11 PM
DDLexus
DDLexus's Avatar
I found this online... The poster is using a Polk 8 ohm replacement. I replaced mine with a JL Audio 8" sub a few years ago. Don't recall the imp rating... sorry.
http://www.hawkee.com/shop/review/354793/
Old 03-31-10, 03:30 PM
aslowdodge
aslowdodge's Avatar
well off to home depot for s tube of silicon.
Old 03-31-10, 04:58 PM
wildace
wildace's Avatar
take that thing out and get a single 12 sub in the trunk. trust me u'll never regret it
DmcL325i
07-30-19 06:18 PM
Jazzkanda6
GX - 1st Gen (2004-2009)
11-07-17 06:57 AM
Ty419
03-05-12 06:57 AM
pizitz70
01-04-11 08:38 AM
tjZ06
11-27-07 07:56 PM
Quick Reply: well that didn't take long
