Headlight leveling issue? input
Old 02-21-10, 02:28 PM
Oldguys
Oldguys's Avatar
Default Front headlight leveler
Any idea where the front sensor is located for leveling the lights? Now that I know where the rear one is I'm curious about the front.
Old 02-22-10, 03:16 PM
buggs384
buggs384's Avatar
You know I haven't purchased the part yet so Im not sure. I used Iron toad for the part quote, they seem to have the best prices..
The hardware is held onto the part by three screws looks very easy to seperate.
Old 02-24-10, 07:51 PM
Tee
Tee's Avatar
Here you go.
Attached Thumbnails Headlight leveling issue? input-front-height-control-sensor-1.jpg   Headlight leveling issue? input-front-height-control-sensor-2.jpg
Old 02-27-10, 06:06 AM
Oldguys
Oldguys's Avatar
Did you pull this from the service manual or a CD of the service manual. I've been considering buying the service manual, but I see that they have a CD as well for about 1/10th the price. I'm a little nervous about buying the CD cause as we all know you get what you pay for.... I want to be able to do some of the small work myself and have access to part numbers so I don't waste money buying the wrong parts.
Old 04-07-10, 08:03 AM
cincin
cincin's Avatar
I had a Headlight leveling warning light.
I pulled fuse #25 on passenger side and warning light went off.
Then I aimed my headlights using a flat screwdriver on the star wheel.
This is the cheap fix.
Old 04-07-10, 09:33 AM
et025
et025's Avatar
cincin - After you pulled the fuse were the headlights aimed down more than normal, like when the car is starting up? Your remedy sounds like the cheapest fix. Thanks
Old 04-08-10, 04:45 AM
PRSUIT460
PRSUIT460's Avatar
It's not a fix it's a band-aid.. A little irritating too. When I bought my LS my headlights were not leveling and I checked the fuse and it was missing. I had gotten that malfunction message once in awhile after I put the fuse in.
Old 04-10-10, 09:45 AM
et025
et025's Avatar
Oh i see. I guess its either i drive around with the error message or cough up the dough and change the sensor. thanks
Old 04-12-10, 02:50 PM
nc356
nc356's Avatar
Whoa a minute fellas:
This thread is about a car with standard, not air, suspension.
Aleluxanja said there's a single sensor for headlight level at the right rear; maybe he's correct.
But for sure: all the pix and drawings that followed are showing the 4 level sensors that are exclusive to air suspension cars.
Old 04-14-10, 07:04 AM
PRSUIT460
PRSUIT460's Avatar
I have a non air suspension car, there is a sensor on the driver front and driver rear, like on the pictures posted.
Old 04-14-10, 02:48 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Correct, every Lexus (equipped with HID's) i know regardless of suspension comes with two sensors to measure the difference in leveling and adjust headlight accordingly.
Usually on the drivers side front and rear. Sometimes all they need is some adjustment, other times they need to be replaced, or the motors in the headlights are the culprit.
Old 04-14-10, 02:50 PM
nc356
nc356's Avatar
OK, when all else fails, we read the directions!
CDW91 is on to something: according to the factory electrical diagrams, non air suspension cars have front and rear height sensors, both on the driver's side! The front is same as for air suspension cars, but the rear is a different part! And no sensors on the passenger side.
Old 07-05-10, 06:54 PM
Oldguys
Oldguys's Avatar
Default Fixed It
Got the replacement part for the drivers side rear sensor from Parts.com and swapped it out this weekend. Best bet is to remove the rear wheel. There is a lever button on the wiring harness that allows you to disconnect the sensor. Supper easy to replace. Dang blinking light on dash went away and head lights now aim properly instead of at the ground. Interesting that two dealerships said they needed to replace both front AND rear sensors to fix the problem. Gotta watch those guy's closely.
Old 07-07-10, 10:21 AM
buggs384
buggs384's Avatar
Oldguys
can you post the part number from parts.com, I still need one.
And how much?
Old 07-10-10, 02:11 PM
Oldguys
Oldguys's Avatar
Default Rear drivers side leveling sensor
Part Number: 8940850060
Cost $313.19 (shipping alone was $40 which is insane plus a $2 handling fee)
This is for a 2006 LS430 without air suspension. I believe this is the same part for all non air suspension models of the LS430.
Make sure you put some electrical grease on the pin connector when you assemble.
Quick Reply: Headlight leveling issue? input
