step-by-step timing belt replacement LS430
Old 01-08-15, 06:10 PM
  #76
randal
randal's Avatar
Originally Posted by rkw77080
Agreed - there are lots of nuts, bolts, and loose pieces to remove and keep track of...
When I did mine, I used sandwich zip-lock bags to keep all the nuts and bolts together and tape it to its associated part. When comes time to reinstall the parts, I did not have to guess which bolts/nuts go with which part. Just an idea...
Great idea, rkw. Thats the only way to go!
Old 05-05-16, 06:12 PM
  #77
montanaboy
montanaboy's Avatar
Why don't post #4 and #5 photos show up?
Old 05-07-16, 05:23 AM
  #78
2KHarrier
2KHarrier's Avatar
Unfortunately, that post is 7 years old, and what ever server those photos were on may no longer exist. That's one of the few inherent problems with these forums. The older posts/threads either drop off the server, or the photos disappear.
Keep searching and I'm sure you'll find detailed pictures. This is a highly discussed topic.
Old 05-08-16, 05:16 PM
  #79
Pittsburgh
Pittsburgh's Avatar
Default Problem during timing belt replacement
Let me start off by saying I'm new to this site and haven't done much mechanically to cars yet. Previous to this I've changed oil, brakes, rotors... That's about it. I researched this timing belt change a decent amount and thought I could handle it. Everything went so so until the crankshaft bolt. I didn't have an impact wrench that would fit, so I tried the starter bump method as described on here and on videos online. I bumped the starter several times
1) I don't think it worked (can't get bolt off, may have moved a little but not sure)
2) I tried it a second time, and now the starter won't engage at all.
I charged the battery to make sure I had enough juice. I did, and it still did not engage the starter.
I plan to borrow an air compressor and buy a shorter impact air wrench. Hopefully that will work.
My questions are:
1) Do you think I damaged my starter?
2) Is there a way to test the starter?
3) Should I put everything back after replacing the timing belt and hope it starts then?
I'm worried that I'll have to take everything apart again if the starter doesn't engage when completed.
Any help is greatly appreciated,
Ian 2003 LS430 157k
Old 05-08-16, 06:02 PM
  #80
Pittsburgh
Pittsburgh's Avatar
By "not engage", do you mean the starter will spin but not engage the flywheel, or does the starter spin at all?
I don't believe it spins at all... It would spin the crankshaft bolt if it would spin, correct?
Old 05-09-16, 04:21 AM
  #81
Pittsburgh
Pittsburgh's Avatar
If the shifter was in "P" or "N", and the starter did not spin or at least make a clicking sound, then you may have blown a fuse (best case), or possibly damaged your starter (Worst case).
In the process, previous to this, I was attempting to remove the radiator. I accidentally unscrewed a bolt(top, right, in front of the radiator) that was part of the a/c line. Gas violently blew out. I thought it was unrelated to the starter at that time. I read a few things about a/c compressors becoming stuck when the pressure is released. Do you think this is related? Would I just have to add Freon, or did I destroy my compressor?
Old 05-09-16, 05:01 AM
  #82
911LE
911LE's Avatar
I'm guessing you are not using a factory service manual to guide you. At this point with the starter and ac issues I think you might be in a little over your head. In your case I would have the car towed to a shop to complete the service. If the timing isn't set exactly you risk destroying your engine. You already cost yourself an ac recharge and an as yet undetermined electrical problem. Cut your losses and have a pro take over.
Old 05-10-16, 02:45 PM
  #83
Pittsburgh
Pittsburgh's Avatar
With a locked-up A/C compressor, the starter will still be able to turn the engine (the belt will slip and squeals at the A/C compressor pulley). There is a slight possibility that when you tried to bump start the engine to loosen the crankshaft bolt, the pinion gear in the starter is wedged by the flywheel and was not able to retract back into the starter housing. This COULD disable the starter. Try wiggling the crankshaft bolt back-and-fro to see if you can free the pinion gear (it's spring-return) from the flywheel.
You guys are great, thanks for the advice. I'm going to take it in unfortunately... I was under-prepared and overconfident. Another lesson learned :/
Old 05-10-16, 03:42 PM
  #84
911LE
911LE's Avatar
Nothing to be ashamed of. Some people never attempt to fix anything themselves. We were all beginners at some point. If you really do want to learn ask the shop you take it to some questions. Most are willing to show you what the various systems are, how they work, etc. Get a service manual and read it and try to diagnose something else and fix it. There is no substitute for hands on experience. YouTube videos are great but they rarely show all the steps or tools necessary which can lead to trouble.
Old 05-18-16, 04:30 AM
  #85
Pittsburgh
Pittsburgh's Avatar
Default Update
So I had it towed into a dealership. I had everything out and organized except for the crank bolt. I previously bought all parts on Amazon or an auto parts store, which I had them replace:
Timing belt
Thermostat
Two pulleys
Hydraulic tensioner
Water pump
8 spark plugs
The dealer had to recharge a/c as well. There was no problem with the starter (not sure why it wasn't engaging when trying the starter bump method).
$675 dealer costs (including a/c recharge)
$240 for all parts
$915 total ($115/hr labor) It could have been a lot worse I think... Thanks again for the help.
Old 01-05-17, 12:39 PM
  #86
vadorade
vadorade's Avatar
For those who have changed their own timing belt, is it necessary to jack up the front of the car? The only reason I can see to jack the car up is to remove the bottom cover, but i can remove it without jacking. If needed, what method did you use? (Ramps, stands, central jack, etc). I am about to tackle the job, and would rather have the front wheels on the ground for stability if possible.
Old 01-05-17, 01:47 PM
  #87
911LE
911LE's Avatar
It is not absolutely necessary to lift the front of the car. It makes it easier for tasks like removing the radiator and trans lines. Removing the ac compressor bolts (2) is the other step in which it may be helpful. They can easily be removed from the front once you know where they are. I used jack stands when I did mine. If you are worried about stability you could always raise the car to remove what is necessary and then lower it for the remainder of the work.
What are you using for instructions? The video in the diy section is quite helpful and shows the correct alignment for the timing components before removal. The factory service manual is actually incorrect on this step but has the correct torque values for various parts. I would assume you are doing the water pump, tensioner, and idler pulleys at the same time?
Old 01-05-17, 02:14 PM
  #88
vadorade
vadorade's Avatar
Thanks for the quick reply. For the instructions, I have watched the video in this thread about ten times, and there are also other videos on YouTube being performed on the same engine (Toyota Tundra I believe). Do you happen to remember what part exactly was wrong in the service manual? I was thinking about buying a manual for more thorough directions, but may pass if the info is not helpful.
Old 01-05-17, 02:35 PM
  #89
911LE
911LE's Avatar
The manual is definitely helpful. The correct procedure is to line up the timing mark (0°) on the crank with the pin (pointed out in the video). This will line up the cam pulleys with the cast-in "T" on the rear cam covers. The factory service manual says to rotate the crank 50° from straight up before you remove the tensioner and belt but this is too far and nothing lines up. The guy on the video is correct.
Old 01-05-17, 03:54 PM
  #90
911LE
911LE's Avatar
I did a short write-up on timing belt alignment on Post #72. Check it out and let me know if you have questions.
Those pics aren't correct. Lining up the timing marks as you have shown is correct only for verifying correct phasing. If the marks don't line up the crank needs to be rotated 360°. For tensioner and belt removal the crank needs to be advanced until the notch on the pulley lines up with the pin behind it. This will advance the cams so they line up with the "T"s on the rear covers. This position has the least amount of pressure on the valve springs and keeps the pistons as far away from the valves as possible.
Quick Reply: step-by-step timing belt replacement LS430
