engine ticking...
engine ticking...
anyone experiencing or experienced a ticking noise from the engine? My 2001 LS430 has 69k on it and the engine is ticking. When I opened the hood this afternoon, i can also hear what sounds like... when you suck on a straw and tap on the end... covering air flow... it follows the rhythm of the ticking. dont know if there is any hydraulic hoses that were loose... at first i thought that it was probably the engine slightly misfiring... i will not rule that out though.. cuz i haven't changed the plugs yet. any insights?
Can you isolate where it's coming from? A stethoscope with an open-ended hose is often a great tool for tracking down the source of noises like that. Just move the open hose around very close to the engine (or other components) and listen. It's like a homing device.
no.. using premium .. highest available on guam is 91. mebe the gas here has gone down in quality... so it's a knock i'm experiencing?
The Check Engine light just came on! probably swing by the dealer to have it checked.
