View Poll Results: Does it work?? Did it ever break??Repaired??
Yes it Broke and had it reapired....
73
27.55%
NO. The Suspension works like a charm...
176
66.42%
YES, my AIR CONTROLLER broke it...
16
6.04%
Voters: 265. You may not vote on this poll
LS430 UL with Air Suspension...Post your Issues Here
#136
KYB decision - accessories needed?
BNR34 and Lavrishevo, I am going to pick up the KYB struts, coils and mounts. Are there additional parts, Boots, covers that also need to be ordered? Or factory parts linked that need to come out? (i.e... control arms, links, bushings..etc)
I called one of the 3 Lexus dealers in the Boston area and you wouldn't crap they were saying about the suspension and how it couldn't be switched to traditional for less then $6-8K !!! Complete BS!
Obviously this is a major decision so I'd like to be as knowledgable and prepared as I can be.
Very grateful!
Very grateful!
#137
Yes, the boots should be ordered as well. Forgot about those. They are mainly there for weather protection and considering where you are located it would be helpful.
Yeah, don't bother with the dealer on this one. They will be a total rip off. On my old LS400 I replaced the coils and struts / shock with KYB's and Tanabe springs. Lowered it about 2.5 inches. Anyway, parts cost me about $800 and labor was about $400.
For any OEM parts check out Lexus of South Atlanta Parts. The best dealer prices I can find.
#138
Well it looks like I potentially might have an issue with my air suspension. I just installed the ASC-680 last week and have been driving on setting 5 for the front and setting 3 for the rear. Well today I noticed it kept trying to put air in the passenger rear air bag and that that side was sitting lower than the driver side rear. I then changed my setting to 5 in the front and 4 in the rear since it was already at that level. Now it only tries to put air in it every now and then. Not sure what the issue is but based on messing with it earlier I think that the height might be stuck at 4 and isn't willing to air up to 3. Any thoughts?
#139
I can just share the fact that my spring system (meaning the air portion of the strut) acts the same way in the rear. Compressor tries to raise it, but it doesn't move past whatever mysterious setting where it wants to stay set. Still stays up off the lower limits quite well though. Allows me to drive while I figure out the best course of action.
The damping, however, does not function properly. Like a pogo stick...
#140
Are you currently running the ASC680 as well?
#141
You might want to jack it up and have a look at the sensor arm also. I know the datatsystems is an easy install, but make sure you didn't try to go too low and mess something up. Usually whatever issues I had with the air were settled by jacking it up and the going onto a flat surface and doing the back and forth thing a few times. Hope all is well though with your ride.
#143
The air controllers are nice but most say the prematurely cause the bags to fail.
I have changed my mind that I was going to replace the stock bags when they start to leak. I found a very lightly used set that I purchased on eBay. There is a slight risk buying used but with only 50K on them it was too tempting. Now watch me not have any issues for another 100K... Lol
#144
Regarding the Air Shocks, Sewell Lexus seems to indicate 3 different part numbers depending on the year of the car.
01-02 = 4801050110
03 = 4801050120
04-06 = 4809050130
Any differences between them.
I would like to get the air shocks for the 04-06 and replace 2 of the air shocks in an 01. Are they compatible? i.e. will they mount and fit the same as the 01's. will the air suspension system play nice"?
Thanks.
01-02 = 4801050110
03 = 4801050120
04-06 = 4809050130
Thanks.
#145
01-02 = 4801050110
03 = 4801050120
04-06 = 4809050130
Thanks.
01-02 = 4801050110
03 = 4801050120
04-06 = 4809050130
Thanks.
#146
01-02 = 4801050110
03 = 4801050120
04-06 = 4809050130
Thanks.
01-02 = 4801050110
03 = 4801050120
04-06 = 4809050130
Thanks.
#147
My battery died and now my rear is up and my front not so much. Anyone else had this issue and if so how'd you fix it? This is the first time I have had issues really, it acted weird once, so I jacked it up and it went back but this is the first time it's stayed. HELP!! LOL...
#148
#150
Do a soft reset by disconnecting the negative for 30 seconds and reconnecting. Then try lowering and raising the suspension. If this does nothing then you need to take a look at the rear height sensor. It may have failed. Inspect the system closely for any damage or leaking.
