Suspension spring discussions (The Mother Thread)
Old 08-16-12, 02:15 PM
  #376
Hiroshi12
Hiroshi12's Avatar
Originally Posted by SpencerT
megan coilovers.
kyb excel g shocks and tanabe df210s gave me the 1.8 inch drop and is a 9/10 when compared to stock ride.
Anything stiffer than that and ride quality will likely suffer.
I bought Springs for $150, Shocks for $380, all the oem mounts, insulators and bumpers for about $300.
It ended up costing well over the price of the entry level megan coilovers.
Spend about 600 on some megans then set them at the softest setting so your ride is still comfortable.
And those should easily give you a 2"+ drop
I'm glad I read this thread because I am having the same debate with myself about how to lower my LS. I think I am sold on coilovers. Same or slightly less cost than shocks/springs, adjustable ride and a lower drop? What's not to like. Thanks.
Old 08-16-12, 02:30 PM
  #377
Hiroshi12
Hiroshi12's Avatar
Originally Posted by fknISC808
Sorry fellahs, dont know where to post this and figured this is the best place. I have a customer who came into my body shop with a 94 LS 400 with stock air. He wants to swap that out with Megan coils, my question is, are the check lights going to light up on the dash? Anything I need to worry about? Thanks for the assistance in advance.
Had this same conversation recently with a shop I was pricing Megans with. They said the "stability control" light will come on when you remove the air suspension setup. That's just one opinion though...so, not 100% sure.
Old 08-16-12, 02:50 PM
  #378
xinkid
xinkid's Avatar
Not true, at least on the 98, replacing air struts with springs did not result in the stability control light coming on. That system relies on speed sensors in the hubs, not related to struts. I told the mechanic he needs to pull the fuse for the air pump. So far no warning lights.
Old 08-17-12, 10:51 AM
  #379
Hiroshi12
Hiroshi12's Avatar
Good tip. Thanks. So, i guess there is no need to actually remove the pump since removing the fuse will prevent it from cycling?
Old 10-13-12, 06:45 PM
  #380
ls4001998
ls4001998's Avatar
Arrow Lowering Spring for 98 LS 400
What are the best lowering springs for 1998 LS 400?
Sounds like H&R? I'm leaning towards Tanabe , suggestions?
How much would goodyear cost for labor to instal them?
Thanks
And can i get the springs without any new shocks?
PICTURE OF MY LS
http://distilleryimage3.s3.amazonaws...0a1d0365_7.jpg
Old 10-13-12, 08:01 PM
  #381
SpencerT
SpencerT's Avatar
Go with tanabe. They are easy to find and I am very pleased with mine.
goodyear will probly quote you like $750 because the book says you need to drop the rear axle.
Do it yourself for $100 in tool rentals (that gets refunded) and 6 hours time.
if you get springs without shocks, your shocks lifespan will be shortened.
or you could just go the smart route and spend 600 on a set of megans.
thats what I would do if I ever had to do work on my shocks again,
Old 10-13-12, 08:04 PM
  #382
RA40
Super Moderator
RA40's Avatar
We have some past discussions:
FAQ:
https://www.clublexus.com/forums/ls4...questions.html
The suspension springs:
https://www.clublexus.com/forums/ls4...er-thread.html
Install $200-$250.
You'll want new shocks like the Bilstein but might as well just buy the Megans.
Old 10-13-12, 08:09 PM
  #383
SPhoto
SPhoto's Avatar
Sweet LS dude! But yeah might as well pick up coilovers.
Old 10-14-12, 10:14 AM
  #384
ls4001998
ls4001998's Avatar
How much are coilovers? What is the difference? *noob*
Old 10-14-12, 10:59 AM
  #385
SpencerT
SpencerT's Avatar
megans: 600-1000
The only difference is the number of settings for ride hight and stiffness.
Old 10-14-12, 02:35 PM
  #386
ls4001998
ls4001998's Avatar
megans: 600-1000
I'm not going to mess with setting and if I can order TANABE DF210 Lowering Spring off az.com for $263.52 than I rather do that and pay some mechanic 100$ to put them on. Surely Goodyear won't charge more that 100$, my family is there always with out car problems and they know us by name.
Background: I just spent around $400 for a new starter, it died.
Also had $3,000 paint and dents repaired by State Farm
Just spent 400$ on the JL W3s
(trying to get paint to 1 tone instead of 2) (front and back bumper are painted the 1 tone and one said panel after repair is 1 tone, only 3 more panels than whole care is imperial jade 1 tone)
moral of story: not looking to spend a lot on suspension - 2 inch drop for 300$ sounds good to me
Old 10-14-12, 04:09 PM
  #387
SpencerT
SpencerT's Avatar
Good plan. I doubt it will work out like that though.
Goodyear will not charge you 100. Firestone quoted me 750 because the ASE book says you need to drop the rear axle. Find a shop that wont do that and they will still charge you 4 to 5 hours labor minimum. Which will be 400-500 at goodyear.
Plus if your shocks have alot of miles drop springs will kill them alot faster...
Get a quote from goodyear and get back with us
Old 10-14-12, 04:55 PM
  #388
PureDrifter
BahHumBug
PureDrifter's Avatar
just LoL.
your (likely original) factory shocks aren't going to last very long at all if you put the tanabe's on your car, so you'll be paying for labor twice since you'll need to swap those out soon too. Coilovers come with new dampers, and allow far more flexibility with ride height and comfort.
no way you're going to get a big-name chain to swap your stock shock and springs out for $100, even if they do "know your family" unless they feel like losing money.
You REALlY need to search, and listen to the advice you're being given.
Old 02-23-14, 10:20 AM
  #389
Hiroshi12
Hiroshi12's Avatar
Originally Posted by PureDrifter
3 things.
1-pretty much every controller will have Japanese instructions, so good luck installing/wiring it.
2-the air shocks are notoriously prone to leakage, and are ridiculously expensive to replace with OEM
3-its VERY possible that using the air susp. controller will kill 1 or more of the OEM airbags putting you in a very precarious situation.
I went back and forth myself trying to decide on whether or not to get the Japanese air ride controller and in the end went with the coil-overs for the above stated reasons. I saved all 4 OEM air struts and just sold them via CL to a guy who has a controller and wanted spare struts for when the inevitable happens. He's got the spares - and I made $400. Win!
Attached photo is his car in front of mine. Pretty much stock, except he's got 18" rims from an '04 LS...I think.
Attached Thumbnails Suspension spring discussions (The Mother Thread)-imag0270.jpg
Old 02-23-14, 09:05 PM
  #390
Akito san
Akito san's Avatar
hey guys well after picking up a 94 LS seems this High mileage suspension its in need for replacement once ready will definetly go with Megan coils just seems best when availability if anyone knows of any discounts on cash purchases please PM me the cheapest ive seen them its $600 here in industry CA on their CL add.
Quick Reply: Suspension spring discussions (The Mother Thread)
