engine temperature watchdog mod
Old 04-18-16, 06:09 PM
qha_vn
qha_vn's Avatar
Default engine temperature watchdog mod
just done a simple mod to add engine temp and alert into cluster. so happy with the result
costs me about $120 and a few hours working. i bought it from http://www.ebay.com/itm/131760063134?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Attached Thumbnails engine temperature watchdog mod-img_2666.jpg   engine temperature watchdog mod-img_2668.jpg   engine temperature watchdog mod-img_2656.jpg   engine temperature watchdog mod-img_2652.jpg   engine temperature watchdog mod-img_2662.jpg
Old 04-20-16, 05:25 PM
timmy0tool
timmy0tool's Avatar
pretty neat but i would like to know actual water temperature and not just the temperature of the block. still a good idea though.
Old 04-20-16, 05:49 PM
qha_vn
qha_vn's Avatar
thanks. you are right, the block temperature measurement may not be precise compared to that of the water temp sensor, but in terms of monitoring and alert, it is way better than the stock gauge. I think the difference is acceptable.
I will compare its readings with temp sensor's when it becomes possible.
Old 04-20-16, 05:52 PM
timmy0tool
timmy0tool's Avatar
you can obtain an OBDII reader/monitor/gauge which can tell you engine parameters in real time, like coolant temp, engine speed, vehicle speed, load etc. there are LOTS of different monitor gauges out there, but probably cost much more than what you paid.
Old 04-20-16, 07:03 PM
Yamae
Yamae's Avatar
Timmy, an OBDII scanner is not OK for his car.
Old 04-20-16, 09:00 PM
qha_vn
qha_vn's Avatar
that's correct Yamae, but i am able to use this device to get some of the numbers. just to check the difference of the watchdog readings and sensor
Old 04-21-16, 05:31 PM
timmy0tool
timmy0tool's Avatar
i'm curious, is there some negative effect on running a scanner while driving?
i have buddy running one on his 1UZ, though it's in an 85 celica so he used the OBD port for RPM, speedo, voltage, and temperature readings.
Attached Thumbnails engine temperature watchdog mod-11000607_10153259347118392_862895171458120256_n.jpg   engine temperature watchdog mod-11351080_10153028334413392_790307233_o.jpg   engine temperature watchdog mod-12931018_10153708267908392_3678030099532617273_n.jpg
Old 04-21-16, 05:57 PM
qha_vn
qha_vn's Avatar
those are available in obd1 engines, this is one of the ways I have used
Old 04-21-16, 06:15 PM
dicer
dicer's Avatar
There would be no problems always running a scanner, just the hassle of turning it on and selecting the pages you want.
Old 04-24-16, 05:49 PM
qha_vn
qha_vn's Avatar
update comparison between watchdog metal temp and engine temp sensor. the temperature readings were exactly the same from 33 to about 55 degree C (warm up) but then they started to be different from that point up. maximum (and most of the time) the readings of watch dog were about 8 degree C lower than that of the engine ECT (read by TOYOBD1)
anyone suggest a reason, and watch dog temp sensor installed location? thanks
Attached Thumbnails engine temperature watchdog mod-temp-read-1.png   engine temperature watchdog mod-temp-read-2.png
Old 04-24-16, 09:02 PM
qha_vn
qha_vn's Avatar
this is where I installed the sensor now
Old 04-25-16, 12:43 AM
Stroock639
Stroock639's Avatar
does the LS have an oil temperature sensor? the PID for oil temperature never becomes active on any of my OBD-II apps
Old 04-25-16, 11:02 AM
timmy0tool
timmy0tool's Avatar
the one he was using is for OBDII and his motor is a 95-97 model, pre-VVTi, with the stock ECU.
Old 04-25-16, 12:21 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
not as far as I know.
Old 04-25-16, 02:53 PM
Stroock639
Stroock639's Avatar
damn i guess it's just such a tank it doesn't matter what the oil temperature is lol
but for real how can it not have one? how would it know if the oil is getting too hot? it's an LS 400 so not that it would though haha
Quick Reply: engine temperature watchdog mod
