OEM Aristo Wheels on a Toyota Celsior - What size Wheel Spacers??? - HELP!!!
Old 11-15-15, 09:52 AM
pyr8
pyr8's Avatar
Default OEM Aristo Wheels on a Toyota Celsior - What size Wheel Spacers??? - HELP!!!
I have a set of OEM Aristo wheels I am trying to put on my Celsior.
The rear wheels fit, however the fronts rub on the break calipers and prevent the wheel from turning.
Does anyone know what size/type of wheel spacer will correct the issue?
Thanks in advance all!
Old 11-15-15, 10:17 AM
lev00221
lev00221's Avatar
More info needed:
Year model Celsior?
Pictures of wheels?
Most likely you will need a 10-15mm spacer.
Old 11-15-15, 10:46 AM
pyr8
pyr8's Avatar
Originally Posted by lev00221
More info needed:
Year model Celsior?
Pictures of wheels?
Thanks for the reply!
The car is a 94
It's winter here in Canada and I put the Aristo wheels on the back as they have winter tires mounted. We have had snow this week!
You can see in the photo that I still have the original wheels that came with the car on the front as I cant get the Aristo wheels to fit.
Old 11-15-15, 12:13 PM
SteezyLS98
SteezyLS98's Avatar
Lol I been asking about some like this for a min I bought some spacers but now I need another inch so my original lugs won't get caught on the rim it's self it's been 4 weeks hopefully I'm done soon to let you know.
Old 11-15-15, 01:16 PM
RA40
Super Moderator
RA40's Avatar
What production month Celsior? Maybe a month 11-12 of '94. The pic of yours shows the 4 pot caliper on the 95+ model years. The Aristo/GS300 wheel is from the 96 or older. Put the wheel on and measure how much wheel pad space is showing...that will give the minimum then add a bit more. 15mm is a typical safe spacer clearance size on non-BBK/low disk type wheels.
Old 11-15-15, 04:49 PM
Yamae
Forum Moderator
Yamae's Avatar
What a coincidence. The wheel looks the same with the one for a JDM Toyota Crown Majesta UZS171 (1UZ-FE Engine, 16inch wheel 7.5inch wide, 50mm offset) shown below.
https://ja.wikipedia.org/wiki/%E3%83...82%B9%E3%82%BF
A friend of mine once suggested to me use his Majesta's winter tires and I tried to fit those to my 98 Celsior.
The rear was OK but the front interfered with the brake calliper badly. I tried a 5mm spacer but still not enough. I added a 3mm spacer but still the wheel was barely touching. You barely can see that the calliper is damaged partly (the surface paint was peeled off and the aluminium is exposed at the higher area).
If the wheel is the same, I think you need at least a 10mm spacer and need to replace the stud bolts. In my case I gave up using those wheels and bought wheels for a 00 Celsior for winter tires.
Attached Thumbnails OEM Aristo Wheels on a Toyota Celsior - What size Wheel Spacers??? - HELP!!!-wheel-for-crown.jpg
Old 11-16-15, 10:43 AM
pyr8
pyr8's Avatar
I believe the calipers are the same as on the Supra?!
What do you mean by "wheel pad"?
As far as the spacers, will it require a spacer with studs, or can I get away with non stud spacers?
Old 11-16-15, 10:37 PM
RA40
Super Moderator
RA40's Avatar
I don't recall the specs on the Surpa 4 pot calipers other then they are heavier by a few ticks and the rotor is larger fractionally.
These are the LS400 4 pot calipers:
These are Supra Calipers:
The wheel pad is the area that will sit against the hub. (that's probably not the right term I'm using.) The location of where the wheel spoke contacts the caliper will leave a distance between the hub and wheel. Measuring this distance and adding a bit more will allow wheel-caliper clearance.
There are spacer with built in studs and without. If using the ones that are built in, your wheels will need to have appropriate clearance because the studs will stick through on anything less that 25mm. They will need these recessed areas. Most factory wheels have them but some may not.
Attached Thumbnails OEM Aristo Wheels on a Toyota Celsior - What size Wheel Spacers??? - HELP!!!-wheel-back.jpg
Sean2jz
GS - 1st Gen (1993-1997)
05-09-18 11:45 AM
StarkoS14
01-18-10 01:59 PM
GSV8
12-07-06 11:00 AM
1998GS400
Wheels, Tires & Brakes Forum
11-30-03 04:07 PM
Quick Reply: OEM Aristo Wheels on a Toyota Celsior - What size Wheel Spacers??? - HELP!!!
