confusing issue. ohms testing a lock-up soleniod
here is an interesting, and frustrating to me, issue. The lock up solenoid for the ls400
the first pdf, shows Resistance: 5.0 ∼ 5.6 Ω
the second, for my 95 ls400 says, Resistance: 7.5 ~ 8.5
they are both the same part number 35280-50010, why in the world would the resistance be different?
ls400 part number found here
http://www.lexussouthatlantaparts.co...528050010.html
first pdf found from this post
https://www.clublexus.com/forums/ls-...ode-fixed.html
The same reason there are always errors and discrepancy's in manuals and parts listings, descriptions, specs or what ever . Some times the proper info goes through so many people (channels) that it gets mixed up or skewed . Or it could be a legitimate engineering change and upgrade that is not noted. To find out you would need to search for service bulletins and other such information.
BahHumBug
I actually have a full Lexus '95 OEM repair manual laying around here somewhere. I'll dust it off this weekend and check it to give you the correct values or report a mismatch.
I don't trust repair manual PDFs without the identifying numbers (there is supposed to be a 5-6 digit code to identify which manual it is from).
woodsy144
11-15-18 02:19 AM
