Exhaust modifications
Old 10-11-15, 07:56 PM
dicer
dicer's Avatar
Default Exhaust modifications
I've been looking at prices to replace a modified, ie cut up exhaust system.
To replace it with new factory parts would run over $3000. for Ca spec exhaust.
Just something to think about when planning a mod job. If I was going to mod I'd remove the costly stuff and just build the replacements, the next owner might want the original quiet system.
Old 10-11-15, 10:30 PM
cgawelko
cgawelko's Avatar
I had mine built in sections. You can unbolt sections of mine and bolt the stock stuff right back in. Except for the Y pipes which is a **** design as it is. So the 4 rear muffler sections are removable. You can run the very rear. The mid rears. Or two on one side - one on the other - whatever combo you want. Sold it to my neighbor who said it was too loud - put the rear most mufflers on and then it was too quiet lol
Old 10-11-15, 11:02 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
exhaust parts in california wear exceptionally well, and as such the used market for them is VERY reasonable. You can buy a complete exhaust, cat-back, for a couple hundred dollars, sometimes less.
That said, It's cheaper to build a "quiet" performance system than to buy the OEM parts again.
ARH
07-07-17 10:17 AM
saucn
11-30-15 11:17 PM
kazuto88
06-10-14 05:58 AM
Murco
Performance & Maintenance
11-07-13 11:54 AM
pieisgude
27
04-11-11 04:40 PM
Quick Reply: Exhaust modifications
