90 ls4700 - stall out every 5-6 secs
Old 09-09-15, 08:43 AM
djtgreen
djtgreen's Avatar
Default 90 ls4700 - stall out every 5-6 secs
Hello Family,
My 90 ls400 idles smooth until it warms up and begin to stall out every 5-6 secs. I changed the spark plugs, fuel pump relay resistor, fuel pump relay, maf sensor, and coils. Car continues to do the same thing. Fuel pump seems to be good since it runs smooth for 30 minutes till warm up. Im checking the open circuit relay when i get home, anyone have any other ideas. i reset the ecm already. Im stuck after the relay check tonite.
Thanks in advance for your assistance.
Old 09-09-15, 10:27 AM
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus.
On the first gen one of the high list checks when they aren't running well is this thread:
https://www.clublexus.com/forums/ls-...capacitor.html
Other regular maintenance:
https://www.clublexus.com/forums/ls-...ange-pics.html
Some additional reading:
https://www.clublexus.com/forums/ls-...ing-power.html
Old 09-09-15, 01:23 PM
dicer
dicer's Avatar
Temperature related, could be ect, O2 sensors, I would be checking the components not just replacing them unless you have a good supply of parts. Well you may have some when your done. And was the LS4700 a special option?
Old 09-11-15, 09:53 AM
djtgreen
djtgreen's Avatar
Thank you, just got the Capacitors replaced, will put the Ecu back in tonite after work.
Old 09-11-15, 09:56 AM
djtgreen
djtgreen's Avatar
no special option just standard.
Old 09-11-15, 10:52 AM
sha4000
sha4000's Avatar
He was joking since you called it an LS4700 instead of LS400.
Old 09-11-15, 12:49 PM
dicer
dicer's Avatar
Another thing to check is crank position sensor.
Old 09-12-15, 10:48 AM
djtgreen
djtgreen's Avatar
Ok i got the Ecu back in with the new Capacitors, engine runs for 1hr:40mins now before the replacement capacitors it would stall out at 30 mins. Now its stalling at at the time mentioned above. Fuel relay is clicking as the car surges up and down. Im checking crankshaft sensor next, any ideas after this check would be appreciated.
Old 02-20-16, 01:26 PM
jscoda
jscoda's Avatar
did you find out anything?
Old 02-20-16, 07:26 PM
dicer
dicer's Avatar
Running long is not likely the cps, fuel relay clicking could be it, or the resistor, especially if its time related like that as the resistor maybe heating up and changing value a lot, and all depending on the ambient temp there. Be happy it makes it past the 10 to 15 minute crap out barrier that mine and others have run into.
Old 02-21-16, 06:44 AM
fixmiester
fixmiester's Avatar
Default New fuel filter
Didn't see where you replaced the fuel filter; should have been done first, before throwing money at everything.
Ozzzzy
Performance & Maintenance
06-24-16 04:31 PM
mk2supra
26
06-04-14 09:25 AM
xsc2003
12-12-08 08:16 AM
xsahowx
13
10-27-08 09:20 PM
Quick Reply: 90 ls4700 - stall out every 5-6 secs
