What is considered the normal for a 94 ls400 to idle at in park
Old 08-27-15, 09:26 PM
TrAPsTaR87
TrAPsTaR87's Avatar
Default What is considered the normal for a 94 ls400 to idle at in park
My 94 ls400 is idling at 2000 rpms. I would like to kno if that's standard or not.
Old 08-28-15, 07:25 AM
TrAPsTaR87
TrAPsTaR87's Avatar
Thanks for your input. That's what I thought also so I disconnected the tps and it fell down to a parked idle of 1500. I'm going to have the throttle body taken off and thoroughly cleaned in hopes that it will fall to within the proper specs. Is there anything else in the meantime I should have checked ?
Old 08-28-15, 06:16 PM
TrAPsTaR87
TrAPsTaR87's Avatar
Today I had the throttle body cleaned. The front side wasn't that dirty but once I had the throttle body taken off the back side was caked with carbon. Had to take a razor blade to cut through the grime. The idle is still at 2000rpms soTomorrow I am going to check the iac with a volt meter. If that needs to be replaced I will be replacing that.
Old 08-28-15, 06:50 PM
KJG92
KJG92's Avatar
The throttle body on mine was the same way but my car idled at 200 rpm so I sent the computer off. We will see tomorrow if that fixes it. I went ahead and got a iac and gasket just in case.
Old 08-29-15, 05:36 AM
TrAPsTaR87
TrAPsTaR87's Avatar
I looked up prices for the iacv and there going for $800.00 where and how much did you spend on it.
Old 08-29-15, 05:45 AM
AandSC
AandSC's Avatar
eBay has a few for about $40. Or find a junkyard in your area and you should be able to get them for that price also.
Old 08-29-15, 05:57 AM
TrAPsTaR87
TrAPsTaR87's Avatar
I have also been contemplating replacing my 02 sensors. I seen a few on eBay for $25 but understanding you get what you pay for I wonder if placing such cheap sensors in my 94lex will end up becoming a future headache or not. Anyone have any exp with them.
Old 08-29-15, 06:51 AM
KJG92
KJG92's Avatar
I paid $70 for the iac on eBay. It looks good so it's worth a shot if the ecu repair does not fix it v
nobelnabil
09-09-18 03:22 PM
ankurdave
03-13-17 08:20 PM
excaliber
Performance & Maintenance
05-07-15 07:23 PM
Suneet
12
06-07-07 11:33 PM
TGRich
03-05-05 08:27 PM
Quick Reply: What is considered the normal for a 94 ls400 to idle at in park
