P0135, p0420, p0430
P0135, p0420, p0430
My 98 LS400 display error upon scanning the ecu.
P0135: O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0420: Catalyst System Efficiency Below Threshold (Bank 1)
P0430: Catalyst System Efficiency Below Threshold (Bank 2)
please help.
please help.
Super Moderator
Miles/km on car?
Replacing the O2 sensors along with checking the exhaust system for any breaks/leaks. Do both bank 1 sensors on each side. Your car is likely running rich initially so I would also suggest the ECT sensor. Do this soon. If your car requires the cats for annual renew in your country and an error code is read resulting in failure, replacing the cats will be expensive. The O2 sensors and ECT is under $150 stateside if you can DIY.
The cats are pretty durable but excessive unburnt fuel run through them will ruin them quickly. I would imagine that they could be hard to source if not pricey to import.
Miles/km on car?
zajacjoe
05-14-18 10:14 AM
StanVanDam
06-01-10 02:13 PM
