What RPM Should Be @ 70 MPH?
Old 07-06-15, 10:54 AM
Superfast1
Superfast1's Avatar
Default What RPM Should Be @ 70 MPH?
I have a 97 LS400 with the tranny overhauled. Can someone check & let me know what's the RPM should be @ 70 MPH? Mine is at about 2300, 2400 @ 70 MPH. I thought it should be around 2K. Thanks.
Old 07-06-15, 10:59 AM
RA40
Super Moderator
Senior Moderator
RA40's Avatar
That is the approximate RPM range for that speed with stock tires. I want to say that 2K RPM is 50'ish. I'm forgetting since I don't drive ours much.
Old 07-06-15, 11:11 AM
dicer
dicer's Avatar
I don't know for sure. But that looks real good to me. Tire diameter will affect it too. And have you tried to cycle the OD switch on the shifter to see if its going into OD, also when driving be aware to see if the Torque converter clutch is engaging.
Old 07-06-15, 11:55 AM
Superfast1
Superfast1's Avatar
Car is driving & shifting perfect as always. Just thought it's a little high @ 70. Next time, when you drive yours, please check & let me know. Thanks.
Old 07-06-15, 04:56 PM
cobalt91
cobalt91's Avatar
2250 @ 70 mph. Almost 3500 with the od off.
Old 07-08-15, 02:28 PM
v8MyFusion
v8MyFusion's Avatar
Mine is 2300 - 2400.
Old 07-08-15, 02:30 PM
v8MyFusion
v8MyFusion's Avatar
What do you mean cycle the Od switch...? I didn't even know there was a switch for it.
Old 07-08-15, 03:32 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
there is a button on the early model cars to turn off OD on the side of the shifter, but was removed for the 95-up cars with gated shifters.
Old 07-09-15, 08:56 AM
billydpowe
billydpowe's Avatar
thanks timmy, on my LS running 235's on 17" wheels mine is 2200
Old 07-09-15, 10:16 AM
Superfast1
Superfast1's Avatar
Our forum is great. Thanks everyone. Have a great day.
BoNgBlAzE
Performance & Maintenance
02-21-10 06:05 AM
Advent
04-23-06 07:32 PM
TRD_Power
SC- 1st Gen (1992-2000)
22
09-01-05 04:27 PM
SC300 RSB
04-30-02 03:48 PM
Quick Reply: What RPM Should Be @ 70 MPH?
