power antenna replacement
Old 01-25-15, 01:19 PM
msweber97
msweber97's Avatar
Default power antenna replacement
The car wash broke my antenna mast, is it worth getting a replacement mast with the cable or get a whole new assembly?
Old 01-27-15, 10:50 PM
sam12345
sam12345's Avatar
Get the mast but make sure it is steel and not aluminium. Also make sure you take out the piece of plastic gear strip that broke off in there before installing new one. Somewhere on ebay they sell the steel mast
Old 01-28-15, 08:00 AM
Gene01
Gene01's Avatar
It is an easy replacement, although the (graphite-based ?) grease is messy if you have to disassemble the unit to get the remainder of the plastic drive tape out of it. It has been quite a few years since I did it, but I seem to remember that there is a secret code that you key into the channel-select buttons to calibrate the retract to fully seat the antenna.
Old 01-28-15, 07:45 PM
sam12345
sam12345's Avatar
No secret code just turn radio on put in turn radio off. But you need two people (one at the radio and one at antennae) just make sure gear tape is removed from old antennae or antenna will not seat all the way.
Old 01-29-15, 12:49 PM
dicer
dicer's Avatar
http://www.lexls.com/tutorials/audio/powerantenna.html
Old 01-29-15, 03:54 PM
msweber97
msweber97's Avatar
sweet, ordered a replacement mast already and was able to pull the whole cable out, so wont need to take the motor apart and get pieces out. Seen a couple videos on how to do it and now the write up for it, thanks guys!!
Old 01-29-15, 05:22 PM
sam12345
sam12345's Avatar
Hope you bought the steel one
Old 01-30-15, 02:31 AM
dicer
dicer's Avatar
Where to buy them at? Steel etc.
Old 01-30-15, 05:28 AM
sam12345
sam12345's Avatar
http://www.amazon.com/AntennaX-Power-Antenna-Replacement-Lexus/dp/B007EHOSH8
chrismoyer
05-13-17 03:13 PM
b2884987
RX - 1st Gen (1999-2003)
12-15-16 11:13 PM
b2884987
12-14-16 02:36 PM
friarush
04-23-15 10:28 AM
hwallen172
SC- 1st Gen (1992-2000)
11-10-01 08:42 AM
Quick Reply: power antenna replacement
