Replaced Compressor
Old 11-08-14, 08:32 PM
Catbyrd1
Catbyrd1's Avatar
Default Replaced Compressor
Still do not have any heat-but AC is working check fuses heater fuse was blown still no heatcan anyone help
Old 11-08-14, 08:34 PM
Catbyrd1
Catbyrd1's Avatar
I have a 1991 LS400 & 1999 LS400 both R very nice looking car
Old 11-09-14, 05:15 AM
johnnyg66
johnnyg66's Avatar
Did you have heat before you changed the compressor??
Coolant level or stuck thermostat.
Old 11-09-14, 09:34 AM
sha4000
sha4000's Avatar
If you have no heat you have to make sure your coolant level is right, Thermostat is not stuck open and there are no leaks in the radiator and hoses.
Old 11-10-14, 07:06 PM
timmy0tool
timmy0tool's Avatar
i am willing to bet there is air in the coolant system. you need to bleed the air out using the following method.
http://www.lexls.com/tutorials/cooling/coolant.html
Old 11-14-14, 02:42 PM
aomdedude1
aomdedude1's Avatar
You posted this a while ago, but I would also agree with making sure your cooling system is fully bleed. There is a bleeder screw right at the top of the engine. Also check that this valve is working:
Mine was actually leaking when I bought the car. I have since replaced it (cost 114$ IIRC ) and the heat works perfect now! Basically melts your face off.
BlackRX300
RX - 1st Gen (1999-2003)
33
11-19-21 06:38 PM
biacs
08-24-18 07:02 AM
Lexus400Dd
15
06-12-13 04:50 PM
Lexushead
03-08-09 07:19 AM
Quick Reply: Replaced Compressor
