Ls 400 coolant leak
Ls 400 coolant leak
Unable to locate coolant leak coming from under air chamber housing right close to bypass hose in the front, any help out there? And what is the best coolant to use
I had a small dribble leak just under the thermostat inlet. I replaced the hose and both spring clamps. No more leak. The hose was original and looked fine so my guess was the clamp was getting loose. But either way the leak stopped.
TyneeGX
GX - 1st Gen (2003-2009)
15
03-25-22 07:01 PM
