are 18" LS 430 wheels/tires on a LS 400 a bad idea?
Old 06-13-14, 08:51 PM
Salted
Salted's Avatar
Question are 18" LS 430 wheels/tires on a LS 400 a bad idea?
There's a LS 400 for sale on CL that has 18" wheels & tires from a LS 430.
Is this a bad idea? I understand the wheels will fit but wouldn't it need different tires to maintain the stock diameter so the wheel speed sensor & abs sensors are accurate and work right?
what do you guys think?
Old 06-13-14, 08:59 PM
sha4000
sha4000's Avatar
They are a good choice and will look good. They work out the box and no need to change the tires which should be 245/45/18.
Old 06-13-14, 09:13 PM
Salted
Salted's Avatar
Interesting.
I would have thought since the 430 was a bigger car it would have bigger wheels & tires. So they're the same diameter as the stock LS 400 wheels?
edit: Just looked up all the info on tirerack and you're right they're very close. the 430 set would have about a .1" taller diameter but that's negligible.
OE 99 LS 400 = 225/60R16.
8.85827" tread width.
135mm = 5.31496" sidewall height.
16 + 10.6 = 26.6" diameter
OE tires on 2005 LS 430 18 x 7.5" wheel = P245/45R18
245mm = 9.64567 inches 4.34055 sidewall height
26.68" diameter
thanks
Old 06-14-14, 01:48 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
LS430s ran the functionally same tire size a '93+ LS400s. 226/60-16 or equivalent. '01-03 (or 04) LS430s shipped with the same size.
Old 06-14-14, 05:12 PM
stopdrpnro
stopdrpnro's Avatar
i'm debating the same those are great looking wheels if you can find them. anybody noticed a big change in gas mileage?
Old 06-15-14, 03:11 AM
Sc0pe
Sc0pe's Avatar
They're basically the same wheel as far as diameter goes. Unless the wheel itself is heavy, I don't think you'll have anything to worry about.
Old 06-18-14, 09:17 AM
kcHotRodLs
kcHotRodLs's Avatar
I love mine. only thing I needed was new set of lug w shorter shank, as the ones from my 16s bottomed out before shouldering up to the wheel.
k
Attached Thumbnails are 18" LS 430 wheels/tires on a LS 400 a bad idea?-img_2307.jpg
bjo
11-09-11 05:48 AM
bhasser
Wheels and Tires Classifieds
08-13-08 04:53 AM
gottahaveit2
Wheels, Tires & Brakes Forum
08-04-03 06:20 AM
gebo
10-14-01 08:30 AM
Quick Reply: are 18" LS 430 wheels/tires on a LS 400 a bad idea?
