No spark on driver side plugs
Old 04-25-14, 12:21 PM
kohatsu
kohatsu's Avatar
Default No spark on driver side plugs
Need some help! The driver side plugs all 4 has no spark. Changed coils, plugs, wires, cam shaft sensor. I'm thinking of replacing distributor cap and rotor, and I heard the crank shaft position sensor? anybody faced this problem before. Car is basically running on 4 cylinders. Did compression tests and all ok with that. car is a 92. Mechanic says that there is spark from the coil to the distributor, but no spark coming out of the plugs. Any Advice. Thanks
Old 04-25-14, 12:55 PM
sha4000
sha4000's Avatar
That's pretty self explanatory if you ask me. Give it a go and let us know so we can advise. What codes do you get on the check engine light?
Old 04-25-14, 02:29 PM
kohatsu
kohatsu's Avatar
ok ill keep u updated thanks
Old 04-25-14, 02:48 PM
Yamae
Forum Moderator
Yamae's Avatar
Sounds like a power transistor in the ignition unit is causing the minor internal leak. Or the clamp diode in parallel with the transistor is doing so. In these cases, the arcing occurs at the ambient but not at the compressed air in the cylinder.
Old 04-25-14, 06:39 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
no spark at plugs--> distributor issue, unless he wasn't getting spark in the cylinder but did when the plugs were pulled.
Old 04-25-14, 07:44 PM
python
python's Avatar
ignitor? btw u probably wont get a cel on
Old 04-25-14, 09:17 PM
Yamae
Forum Moderator
Yamae's Avatar
A minor leakage of semiconductors can't be detected by the ECU. The minor leakage also makes it possible to spark for a few milli meter at 1 ATM.
Old 04-26-14, 05:48 AM
python
python's Avatar
im def. not going to dispute what ur saying yamae. do a ripple test, ive never heard of the ecu causing only 1 bank to not fire..especially in a pre obd2 car..doesn't mean anything other than ive yet to hear of it.
next:it cant be the distributor cap or rotor..each distributor is related to both banks. this was already covered previously by another member having a similar issue.
Old 04-26-14, 06:48 AM
Yamae
Forum Moderator
Yamae's Avatar
I am not saying any about the ripple nor the ECU here. Do you know what is the leakage of electrons?
Old 04-26-14, 07:11 AM
python
python's Avatar
lol..obviously not. I misread ur post..sorry
Old 04-28-14, 05:00 PM
kohatsu
kohatsu's Avatar
Ok guys this is what was the test results. Distributer is good, There is spark at the wires. but no spark in the cylinder. Mechanic did all the checks and compressions is good on all cylinders. He is saying it might be electrical, like something is shorting out. Im thinking of taking it to a shop that specializes in electrical work. Any advice?
Old 04-28-14, 05:03 PM
kohatsu
kohatsu's Avatar
oh yah all driver side cylinders still no spark.
Old 04-28-14, 05:14 PM
kohatsu
kohatsu's Avatar
another thing when they tried to pull codes, they couldn't get any codes to come up. Do u think definitely ecu?
Old 04-28-14, 08:18 PM
python
python's Avatar
makes no sense...ur getting spark from the cap to the wires..no spark from the wires to the plugs?
Old 04-28-14, 08:58 PM
Yamae
Forum Moderator
Yamae's Avatar
It only makes sense when the secondary voltage is not high enough. It requires only 1kV to travel electrons for a 1mm gap at ambient. But in the compressed air such as at 10 ATM, more than 10 kV is needed to have a good spark. Did you check the leakage?
Quick Reply: No spark on driver side plugs
