New Toyota Oil Cahnge Interval - 10K miles
Old 01-16-14, 01:14 PM
Michael
Michael's Avatar
Default New Toyota Oil Cahnge Interval - 10K miles
I have 2013 Camy. I brought the car in for 5K miles checkup and they would not change the oil. Then I've lean that starting 2013, Toyota is recommending the oil changes at every 10K miles. This is due to the fact that they have started to use synthetic oils on new Toyota cars. But every 10K???? Wow. This is going to have Jiffy Lube guys out of business. Going from 3K intervals to 10K interval.
Old 01-16-14, 01:18 PM
Michael
Michael's Avatar
I have 2013 Camy. I brought the car in for 5K miles checkup and they would not change the oil. Then I've learned that starting 2013, Toyota is recommending the oil changes at every 10K miles. This is due to the fact that they have started to use synthetic oils on new Toyota cars. But every 10K???? Wow. This oil change interval change, going from 3K (5K) intervals to 10K, is going to put Jiffy Lube guys out of business.
If this is the case, I can do the same with the older Lexus? You pay more for the synthetic oils but every once a year oils change, I can live with.
Old 01-16-14, 01:19 PM
midwest2
midwest2's Avatar
3k intervals has more to do with marketing than necessity. It has been a long time since a 3k interval was supported in an owner's manual. A cheap oil analysis I believe would support this.
Old 01-16-14, 01:32 PM
LScowboyLS
LScowboyLS's Avatar
10K interval is fine on both cars as long as you are using a top tier FULL synthetic (i.e. Pennzoil Platinum, Pennzoil Ultra, Mobil 1, etc.) just make sure you are using a great filter as well - here is a list of the best
on the Camry, I would actually use Toyota's new 0W-20 oil, no matter where you live, it is stellar! (made by Mobil to a new standard of quality that beats all)
unfortunately, you can't use that oil in an LS400, but make sure to use a high quality top tier 5W-30 or 0W-30 only
SirKong
RX - 4th Gen (2016-2022)
398
09-17-24 10:44 PM
rondocap
ES - 5th Gen (2007-2012)
14
07-05-19 03:24 AM
BensonRX
12-04-14 04:08 PM
relax221
12-12-13 01:33 AM
<VENOM>
GX - 1st Gen (2003-2009)
03-03-03 12:11 PM
Quick Reply: New Toyota Oil Cahnge Interval - 10K miles
