Help! — Locked out of trunk
Old 12-17-13, 09:01 AM
Sololock
Sololock's Avatar
Default Help! — Locked out of trunk
Just bought a 1990 ls400. When i got home to clean everything
I figured out i cant get in the trunk.
The valet lock is not on, my key can lock and unlock glove box (master).
When i hit the trunk release i hear what sounds to be like a relay switch in the driver
Kick panel.
When i try to use the key to open the trunk, it turns but nothing happens.
Is there any way in? My only thought was bust a tail light but will that give me anyroom to hit the latch? Is there a wire i can give direct 12volt? Help me please
Old 12-17-13, 10:51 AM
Gene01
Gene01's Avatar
The tail light is held in by bolts that go through the sheet metal. The holes for the cables are < 1" in diameter, so they would not allow access to the lock mechanism unless you are very, very good with a coat hanger.
Sorry I can't think of a solution to the problem.
Old 12-17-13, 03:49 PM
steve2006
steve2006's Avatar
Bear in mind this is based on a RHD 1997 JDM LS400 ( Toyota Celsior) so the loom may be on the other side.
If you remove the plastic sill trim along YOUR driver's door you should find a wiring loom in there, peel back the insulation tape and in the bunch should be a plain black wire, this is the feed to the trunk release solenoid, strip the insulation from this wire and then momenterily apply 12 volts to it from your car battery.
This should activate the trunk lock solenoid and release the trunk lid.
If the trunk solenoid has failed obviously this method will not work.
As I said this is based on a RHD version so the loom may run along your passenger door on a LHD model.
The photograph below shows the black wire, in my case I cut the wire then connected the 12 volts to the end nearest the trunk,popped the trunk then remade the wire connections and reinsulated.
Old 12-17-13, 06:45 PM
LScowboyLS
LScowboyLS's Avatar
on other cars, I have gotten in a locked trunk via removing the back seat (which is easy on LS400) but I have not tried crawling through from back seat to trunk on an LS400, so maybe some of the other folks here can comment on whether that is feasible on this car. Thinking that gas tank may be in the way.
Old 12-17-13, 07:04 PM
Kansas
Kansas's Avatar
Of course the gas tank and the steel bulkhead in front of it is in the way - on all LS400's, all model years. If I remember correctly, there are only two very small holes covered with grommets on the bulkhead behind the seat back of my 2000 LS400 - not big enough for anything but passing a wire through which was what I did with one of them.
Old 12-18-13, 03:26 PM
JM51526
JM51526's Avatar
I'd try a locksmith before I start taking the car apart...
Old 12-18-13, 05:14 PM
sha4000
sha4000's Avatar
+1 since there is no way to get inside the trunk if the actual locking mechanism is faulty.
Old 01-20-14, 02:36 AM
shanjam
shanjam's Avatar
Have you undone dead lock in the car?if this is on key will not unlock ?
Old 01-20-14, 10:07 PM
Boxcuta
Boxcuta's Avatar
Flathead Screwdriver :]
Chione
14
04-20-20 04:46 PM
1sWt2GS
02-16-13 10:42 PM
scweetrob
SC- 1st Gen (1992-2000)
12-09-11 05:00 PM
MIGS
20
03-31-11 10:13 PM
zxlr8
09-04-02 07:00 PM
Quick Reply: Help! — Locked out of trunk
