Surging and bucking under load no check engine light
Old 11-16-13, 10:08 AM
cobalt91
cobalt91's Avatar
Was your test done with the AFM unplugged? The slow times may be because the ECU is running the mixture fat and pulling the timing.
Old 11-18-13, 08:00 AM
rwdaddict
rwdaddict's Avatar
I found the stumbling issues to be caused from a AFM on the fritz. It didn't throw codes but finally got a known working unit and issue is fixed.
The last issues I have now is the slower acceleration off the line. Only off the line though. If I punch it going like 20 or so it flies. Off the line and the whole way through to 60 it's a dog.
Also when I first start it up in the morning the exhaust is blue.
Old 11-18-13, 08:01 AM
rwdaddict
rwdaddict's Avatar
Also I let it idle in my garage for a bit and when I walked back (the garage door was open the whole time) it wreaked of fuel, running pig rich.
Old 11-18-13, 12:32 PM
LScowboyLS
LScowboyLS's Avatar
how about those pics of the ECU you were going to post?
did you run Yamae's ripple test?
Old 01-31-19, 10:18 AM
LS400SC400
LS400SC400's Avatar
Default Surging LS400
I bought a 92 LS400 with very low miles, as the original owner had died, it sat most of the time for years, and about 5 years back the wife had a new fuel pump installed, and had the gas tank cleaned and sealed etc., due to problems like described here. Since I bought it a few months ago I have done the following, and it has improved a lot, but the problem persists.
So far I have new spark plugs, new spark plug wires, 2 new distributor caps and rotors, two new coil packs, a can of techron, then sea foam, then Lucas, fuel system treatment, but it still surges and pops on acceleration, maybe a bit less when fully warmed. Next steps seem to be a new mass air flow meter, possibly change the fuel pump and fuel filters again, and maybe as a last resort ecu capacitors, but I am a bit out of my depth at that point. Any suggestions?
Gs46046
01-20-24 12:16 PM
Swint
Performance & Maintenance
26
09-09-13 12:32 PM
Kanderson1
10-31-12 07:18 PM
giolex300
04-12-12 10:56 AM
Kbueno
11-25-11 09:06 AM
Quick Reply: Surging and bucking under load no check engine light
