Check engine light on cause vsc on?
#32
definitely replace the battery if it is iffy! - that could definitely solve the entire problem! (that applies to anyone getting any CEL code)
my advice is based on you having already checked out the more routine items (battery known good, alternator charging correctly, all fluid levels correct, belts in good shape, etc.)
#36
I'll check back tomorrow after driving a bit, also PD of the timing is supposedly off by a tooth or so then the car wouldn't even run right correct? I'm thinking about replacing the oil control valve but I just clean it yesterday and still came on today from driving. So I just got the battery replace today since of every place I went to get it check it all turn out to have fail
#37
if you are gonna have more than the stock sound system, you need a great battery AND a high amp alternator (like 160 amp or higher), and if it is a really kickin system, you may even need two batteries!
#40
I really hope the timing is fine, is there another way to test the ocv? Also by any chance anyone may know the part number for both of the ocv if I do replace it I more than likely go oem unless someone got good experience with other brand
#42
PD has pronounced your timing as just fine, therefore, it is!
but seriously, that does appear at a glance to be off - make us some better pics and show each cam
it is sometimes hard to determine whenever a timing belt is slightly off whether it has "jumped" a tooth, or was just installed a tooth off in the first place (when the timing belt was done)
get that service manual out that I sent you and read the timing belt alignment procedure over a few times!
#43
Well I didn't do both side I just wanted to show one side first and if it's off I figure it should be off. So according to the pictures, my timing is still fine?? I am currently not driving the car because don't want to risk anything on it. But if I do replace/redo it I should just change the belt and tensioner? Even tho it have not been a year on the timing belt kit I just got on
#44
nooo, I did not say your timing was fine! - I was making a sarcastic remark as usual!
I have insufficient information at this point to tell you whether it is off or not.
you pics are not conclusive without simultaneous pics of both cams, you have to continue to rotate crank clockwise and see if there is a point where everything lines up
if it turns out that we determine it is truly off, you need to take the worse case that it may have jumped rather than been mis-installed and do the following:
● replace timing belt with correct Toyota, Bando or Mitsuboshi belt only
● replace timing belt tensioner (NTN or Toyota only)
● inspect for any oil leaks and wipe down crank and cam pulleys, idlers with 91% alcohol or brake cleaner
● replace timing covers and/or gaskets if there is any breakage or leaking inside going on - all surfaces inside timing covers are supposed to be dry and oil free
● use the factory service manual to insure the new timing belt is installed and tensioned correctly
check for oil leakage around cams and crank, if the seals are leaking, this could introduce oil into the timing belt area - is the inner surface of the tiny belt bone dry & grippy or oily?
#45
