Hello from Maryland
Old 06-28-13, 11:12 AM
  #31
TNasty
TNasty's Avatar
Please make a thread in the regionals section if you'd like to find out whos in MD. I made this thread to keep progress on my car. Please move if its in the wrong section.
So i tackled my lower ball joints today. It was pretty straight forward. I needed a driver side outer tie rod though. I got a MOOG replacement.
The only things that were a PITA were the speed sensors.
Attached Thumbnails Hello from Maryland-image-1178337810.jpg   Hello from Maryland-image-3616161081.jpg   Hello from Maryland-image-2652525427.jpg
Old 06-28-13, 02:52 PM
  #32
dc893
dc893's Avatar
Did you do the uppers as well? If you are doing just the lowers you do not need to take that much stuff apart. I disconnected everything on the lower portion and let the upper half rest on some blocks. Just let the bottom of the rotor sit on something. Might save you a little time if you need to do this again.
Also might wanna take a quick look at those sway bar end links. They are starting to look a little old as well. Replaced mine and it helped the handling quite a bit. Plus you could probably do it yourself for less than $100.
Old 06-28-13, 03:29 PM
  #33
TNasty
TNasty's Avatar
I just did the lowers. I followed the DIY on lexls.com
But thanks for the advice. That'll save me some time in the future.
I will also look into replacing the sway bar links. Thanks for the heads up.
Old 06-28-13, 07:06 PM
  #34
LScowboyLS
LScowboyLS's Avatar
dang, that would suck having to do steering/suspension work in a parking lot, those of us with carports & garages don't realize how lucky we are!
Old 06-29-13, 04:32 PM
  #35
TNasty
TNasty's Avatar
I have to everything in a timely manner because if something were to happen, I can't leave it on jackstands over night.
I just moved in with my mom last October. Before that, I was living at my dad's house. I had a concrete slab in the back where I would do all my work. It was awesome. No garage/car port though. lol
Old 06-29-13, 04:41 PM
  #36
LScowboyLS
LScowboyLS's Avatar
new inner and outer tie rod ends will make the steering seem like a new car - I am not a big Moog fan any more though, I am shifting over to OEM on the cheaper outers and probably Raybestos Pro on the expensive inners
Old 06-29-13, 06:38 PM
  #37
TNasty
TNasty's Avatar
I hear you on that. The moog outer tie rod was an emergency. I think it was a better choice than the $13 dollar tie rod Advance had. lol I'm trying to stick to all OEM parts when it comes to the suspension and motor.
Lnmarlow
13
03-19-18 01:01 PM
christo19
20
01-15-16 10:01 AM
mark458
05-24-11 10:05 AM
durtysc300
Performance & Maintenance
01-26-11 11:03 AM
One HoT
Maintenance
12
12-29-02 11:51 PM
Quick Reply: Hello from Maryland
