Hello and help hot stalling
I I have searched for ages and have an ongoing issue, firstly I have a uk spec 1997 rectangular headlight model registered 1998.
I have various wiring diagrams that don not match my ecu 34p 22p 16p 28p with 89661-50351
when warm it appears that the IACV doesn't operate at all and vehile will only run with pedal pushed.
If you get a clean start the vehicle will run and run.
The engine m,anagement light is out and the IACV is the later non servicable version.
I have tried carb cleaner on valve and this makes no difference.
Any Ideas please
Any Ideas please
IACV bearings going out and failing ECU capacitors are both common issues on 93-97 models especially - given your symptoms, sounds like you have one or both of those issues
Thank you for the reply- I have a computer safe circuit tester, as I understand there should be 2 ignition feeds and
2 ecu earths. With rhe capacitors my ecu shows no signs of burning or ballooning capacitors.
I take it the capacitors are nothing exotic, I will look at link you gave me .
Thanks.
Thanks.
yes, the correct capacitors to use if you decide to replace them are quite exotic - please use the exact ones, brand and part number, linked to in post#1 of my ECU thread - otherwise the repair won't work
Hi thanks I have bought and replaced capacitors and repeatedly cleaned the IACV and now the issues have become 99% better. if the IACV doesn't settle- I will buy a replacement as mine is non serviceable one. thank you for your help
the 90-94 IACV will work fine on your car (with a couple of adapters for vacuum or water line size), and the cool thing is that the 90-94 IACV is serviceable, so you will have essentially a brand new one for less than $100 invested, rather than close to $1000 for a new one.
if a bearing or a coil has gone bad on the IACV, no amount of cleaning will fix it
I had considered soaking the valve part in duck oil or diesel over night to see if it was crud blocking motor.
I will see how it goes and report back- thank you for the advice
