Help me ........ Please !!!!!!!!
Old 04-16-13, 10:26 PM
Natman92
Natman92's Avatar
Default Help me ........ Please !!!!!!!!
I have a 92 LS 400, I am having problems it stops on me when it is MISTY outside or CLOUDY an about to rain I am thinking it is Moisture can any one give me some answers PLEASE !!!!!!!!!!!!!!!! ??????
Old 04-16-13, 11:02 PM
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus.
The car stalls when it is raining or there is high humidity? There are probably other symptoms but the easiest rather than wild shots is to have the diagnostic codes read. Then you can fix as necessary.
Old 04-19-13, 01:41 AM
Natman92
Natman92's Avatar
The Codes were read an it came up nothing .... One guy I talk to yesterday said that it might be a very small crack in the Distributor an or Rotor Cap an I might have to change it ???
Old 04-19-13, 02:00 AM
cobalt91
cobalt91's Avatar
how many miles? how long have you had your LS? Could be just a tune up. A good way to check is start the car and with it running take a spray bottle and mist the wires. Look for any arcing.(blue sparks) also listen. does it start to misfire? The best way to find out whats happening, is to open the hood and get in there. Don't be afraid to poke and prod.
Old 04-19-13, 06:13 AM
billydpowe
billydpowe's Avatar
YEP, you need to help yourself before you start crying for our help, tell us what YOU have found/discovered and then maybe we can help......
Old 04-19-13, 11:22 PM
LScowboyLS
LScowboyLS's Avatar
Very sound advice.
Old 04-23-13, 09:49 AM
Natman92
Natman92's Avatar
I have gotten the fuel pump changed,fuel filter changed,fuel line cleaned out,tune up,cap & rotor changed, next thing I am thinking is the fuel regulator but I don't know ..............
Old 04-23-13, 08:48 PM
LScowboyLS
LScowboyLS's Avatar
did you take cobalt91's advice and do the test he recommended?
Old 04-24-13, 05:38 AM
billydpowe
billydpowe's Avatar
the only things I can think of is plug wires (good ones) and a faulty coil (cracked), because of humidity causing your trouble..
Old 04-24-13, 08:52 AM
Lavrishevo
Lavrishevo's Avatar
Intake air temperature sensor could also be the culprit.
Old 05-15-13, 04:03 PM
Natman92
Natman92's Avatar
I did that .... Nothing ????????
Old 05-15-13, 04:22 PM
Natman92
Natman92's Avatar
Cool Still having TROUBLE !!!!!!!!!!
Ok Guys I have tried everything U have told me an It Runs for a few days about 3 or 4 then just does not start foe 2 to 4 weeks It has NO codes ...... I checked & changed ..... Cap & Rotor ,Fuel Pump & Filter Cleaned out Gas Tank ...... I Don't know what else to do ..........
Old 05-15-13, 04:46 PM
fixmiester
fixmiester's Avatar
Go back to basics: Compression, spark and fuel. Get a can of starting ether, spray a second into throttle body opening; if it starts and tries to run a few seconds, then you have a fuel delivery problem. If not, check for hot spark at the distributor when cranking. Go from there.
Old 05-15-13, 09:19 PM
Lavrishevo
Lavrishevo's Avatar
Check wiring harness at the trunk hinges to make sure there is no wire fraying. If not, I would look at your ECM / ECU next for leaking caps. That is if you are taking care of the basics. Battery, alternator, etc...
Old 05-15-13, 10:52 PM
LScowboyLS
LScowboyLS's Avatar
yes, when you are pulling your hair out, and don't know what to do, and have tried everything, it seems it always turns out to be defective ECU capacitors
just this month I fixed crazy intermittent problems that could not seem to be traced down on three different cars, just by changing ECU caps!
the cars were:
1995 LS400
1996 Acura RL
1986 Nissan 300 ZX
Quick Reply: Help me ........ Please !!!!!!!!
