??? for those that have done their own valve adjustment
Old 07-19-12, 04:43 PM
kyddo112
kyddo112's Avatar
Default ??? for those that have done their own valve adjustment
Just got a 93 LS400 and I'm in the middle of adjusting the valve clearance using the Lextreme write uphttp://www.lextreme.com/valve_clearance.html)
With the crankshaft pulley marker on "0" and the cam gears lined up with the marker on the head, which valves am I supposed to check first? I was under the impression that I would use the first picture:
then rotate the crank 360* and use the second picture:
My problem is when I do it that way, the peak of the cam lobes seem to be pushing the valves/shims down. I measured the clearances on the second pic with the timing marks lined up (crank and cam gears) and was able to get a measurement since the valve shims weren't being pushed down. Can anyone help me with this.
Here is a pic of the Driver side exhaust cam being measured AFTER the crank was rotated 360*. You can see that the peak of the lobe is away and the valve is uncompressed.
And here is a pic of when the crank/cam gears are lined up to their markers.
Old 07-19-12, 06:34 PM
Dirtybrd
Dirtybrd's Avatar
You will check the valves where the peaks of the cams are facing 180 degrees away from the shim.
Old 07-20-12, 08:59 AM
kyddo112
kyddo112's Avatar
that's what i figured but wasn't sure. i found a service manual online and it showed it the opposite (correct way) of lextreme's site.
Old 01-16-20, 01:00 AM
boss21
boss21's Avatar
hoping someone can help, i have a 1UZ lexus motor i bought and the cams have been removed and are in a box, how do i differentiate between the left hand side bank and right hand side bank camshafts ?
Old 01-16-20, 05:31 AM
python
python's Avatar
the only difference is intake vs exhaust cams...https://www.mylparts.com/v-1993-lexu...--engine-parts
Returd
Performance & Maintenance
06-02-23 07:47 AM
GTX580
02-09-17 02:35 AM
lilprince
Maintenance
12-05-12 04:01 PM
ralsty
10-31-08 10:39 AM
Quick Reply: ??? for those that have done their own valve adjustment
