Considering 235/60/16 for 1996 LS400
Old 04-30-12, 02:22 PM
flip33
flip33's Avatar
Default Considering 235/60/16 for 1996 LS400
Hi,
After trying low profile tires a couple of times, I am going with 16's. My kids seem to find potholes that put the wheels out of round.
I used a tire calculator to look at the 235/60/16 and they are close enough in diameter. I like them because they are nice and fat. Skinny tires look wimpy to me. These are about 9.5 inches wide and should fit. I bought some 16x7 2000 Lexus five spoke wheels.
I found some Sumitomo high performance all season tires that look like a good match to my use.
Am I missing anything? Will they ride nice? Thanks for sharing your ideas.
Old 04-30-12, 02:26 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
yeah, you're missing the fact that your stock wheels are a grand total of 7" wide....
stick to 225/60-16 (the stock size) if you want stock-like results.
Old 04-30-12, 02:44 PM
flip33
flip33's Avatar
What would the non stock like results be?
Old 04-30-12, 03:23 PM
RA40
Super Moderator
RA40's Avatar
This is a minimal change in most respects. You may not notice a difference from 225-235.
Old 04-30-12, 05:12 PM
Kansas
Kansas's Avatar
235/60-16 will fit fine and might even give you an accurate speedo reading. Your seven inch wide wheels will take even wider tires than that. Back in the late 90's, Toyo specifically marketed their 245/55-16 tires for use on standard 16"x7" 93-00 LS400 wheels. The following website provides accurate information on the wheel sizes required for various tire sizes: http://www.1010tires.com/tiresizecalculator.asp
With that said, I would still go with the standard 225/60-16 tires to preserve the cushy ride. Something else is putting your tires "out of round". 235/60-16 tires certainly aren't going to help that. Maybe buy some high quality 225/60-16 tires like the Michelin MXV4 Primacy tires I use on my 2000 LS400 - might cost a bit more but well worth it.
And buy bicycles for your kids to "drive" unless you want them to trash your LS400.
Old 04-30-12, 10:42 PM
VanCityLS4
VanCityLS4's Avatar
235 on a seven inch wide wheel is something that you would commonly see on pre early 90's cars. It would work & be minimally noticeable over stock.
macz
05-19-08 05:20 PM
doyo
Wheels, Tires & Brakes Forum
06-15-07 06:25 AM
aweaver5
04-04-07 01:35 PM
gs4to4
12-13-02 05:40 PM
gebo
12-12-02 01:47 AM
Quick Reply: Considering 235/60/16 for 1996 LS400
