Fender Removal on UCF20/21
hey guys, do any of you guys know how to remove the front fenders on the 1998-2000 lexus ls400? thanks in advance. is there a pdf file or anything?
.. its going to be pretty self explanatory... take a minute to just stare at your fender.. look for all the bolts / screws.
i've never taken a fender off a ucf20/21 but im assuming it goes something like this,
jack that front side up that you want the fender off.
take out the corner light beside the headlight (usually is a hidden screw/bolt behind there)
also at the bottom where the fender wraps under the car there is usually a few bolts / screws there
take the wheel off, and then the plastic liner, there is probably 1 or 2 bolts / screws there
and if I remember correctly when I did my ucf11 fender, you take off that lower piece (two tone on most ls') there maybe one bolt behind this, the lower pieces is put on with clips.
there will be 1 or 2 screws/bolts where the front bumper meets the fender
then the most obvious there is 4 - 6 bolts at the top of the fender where it meets the chassis under the hood, remove those and now that everything is removed it should just come off.
