UCF20 LS400 Brake Master Cylinder, Which is Front/Rear?
Old 05-27-11, 01:14 PM
Cashflo
Cashflo's Avatar
Default UCF20 LS400 Brake Master Cylinder, Which is Front/Rear?
I'm doing my ABS delete and Hydro E brake install this Saturday, I was wondering which line off the master is for the front and which is for the rear?
I've looked around and haven't found any information on it.
Old 05-28-11, 11:44 AM
Cashflo
Cashflo's Avatar
Come on, someone has to know.
Old 05-28-11, 01:11 PM
steve2006
steve2006's Avatar
It's not clear from the exploded diagram,both pipes from the master cylinder go to the ABS block and the brake line distribution is done from there.
Old 05-29-11, 11:24 AM
Cashflo
Cashflo's Avatar
Well on my previous car Nissan 240sx S13, It has 3 fittings, Front/Middle/Rear. Front and Middle each went to a different front wheel and the rear went to a T fitting in the rear of the car. So I'm assuming that the front of the master would go to the front and the rear goes to the rear. If it doesn't work I'm just going to switch it around.
Old 05-29-11, 11:52 AM
deanshark
deanshark's Avatar
I've never worked on these master cylinders (Never even looked at it) but in the old days on my older cars, (70s & 80s) the front pool, was for the rear brakes and the rear, which had the bigger pool, was for the front.
Old 07-26-11, 11:33 PM
Cashflo
Cashflo's Avatar
I have confirmed that the fitting closest to the front of the car goes to the rear, and the other is for the fronts.
Old 07-26-11, 11:51 PM
emarknot
emarknot's Avatar
nothing to add....just curious to the intentions.
is this on/off ebrake app without lockup cuz you controll the pressue...or something different?
Old 07-27-11, 04:12 PM
Cashflo
Cashflo's Avatar
Its for a hydraulic handbrake to lock the rear wheels. I can control the pressure to minimize the amount of lock to my preference. But I was mostly looking to do an ABS delete, as ABS sucks...
mecheng10
Suspension and Brakes
12-22-13 09:12 AM
ihiryu
11-28-12 01:51 PM
CCColtsicehockey
IS F (2008-2014)
20
10-06-11 12:36 PM
Biggu
01-25-09 11:08 AM
Quick Reply: UCF20 LS400 Brake Master Cylinder, Which is Front/Rear?
